voltmeter battery drain?
#695610
02/12/06 01:09 AM
Long story short, I hooked up my voltmeter from my dome light lead which always has current. While I kind of like looking at my battery charge before I start the truck, I wonder if the gauge would be enough to drain the battery (in like a month of non-use). Thoughts?
Sid
89 extra cab 4x4 3.0 5 spd, 216K 4.56, Supra LSD, Lock Rite
Re: voltmeter battery drain?
[Re: Voyager]
#695611
02/12/06 01:55 AM
Electrically speaking, your voltmeter will have very high resistance. Will it drain the battery? Probably.. I'd guess a number of weeks or so.
Use a relay to an ignition activated source.
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#695612
02/12/06 02:20 AM
I think your volt meter's battery will run out before your battery does.
[Re: trythis]
#695613
02/12/06 02:39 AM
It's a standard automotive store guage, but measures volts vs. amps (old school). I'll have to check the package on one at the store & see what the draw is on it.
Sid
[Re: Voyager]
#695614
02/12/06 03:24 AM
ammeters suck -- there's a good reason you don't see new vehicles with them, they can melt down and cause fires.
i'd just wire the voltmeter to a keyed power source, like the radio.
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: kyle-22r]
#695615
02/12/06 03:51 AM
You could try hooking the meter to the cigarette lighter power, that way it comes on with the key in the ACC position so you can see the voltage, or anything off the ignition and the meter will be on before you start the engine.
Automotive volt meters can pull more current than a typical test meter does. I think one that I have on my on-board welder is a 1mA meter with a series resistor to calibrate it. So 1mA is not a huge draw, you probably have 20mA or so from clocks, memory circuits, etc.
[Re: 4Crawler]
#695616
02/12/06 09:02 PM
Thanks all. I'll run it a while & look at routing another power source for the long term. It was just soooo convieneint for my guage pillar mount to tap into that wire <img src="/forums/images/graemlins/smile.gif" alt="" />
Sid
[Re: Voyager]
#695617
02/12/06 09:12 PM
Or you could just add an on/off switch near the gauge so you can turn it off when you won't be driving the truck for a long time. I added one to my gauge pod for switching the pressure meter between fuel and on-board air pressure senders: ![[Linked Image]](http://www.4crawler.com/4x4/CheapTricks/Gauges/Pillar_1.jpg) Gauge pod from our Mosk here on this forum: - http://www.4crawler.com/4x4/CheapTricks/Gauges/index.shtml
[Re: 4Crawler]
#695618
02/13/06 02:59 AM
Nice pillar pod Rodger. Where's that from?
I had 12v probs for A LONG TIME. I ended up getting a very cool volt meter for auto diagnostics from Radio Shack for about $6. It is about 1" x 3" and has diff colored led's indicating voltage from like 9 - 19v. It had alligator clips, but I hard wired it... I love it, cause its an at-a-glance reading, more lites + higher volts. I wanna take it apart and mount the led's in the dash or something, but for now it's velcro'd next to steering column. BTW, it is on a keyed circuit...
1984 4Runner - V6 rear axle (locked by Lincoln), header, plenty of body cancer! Waiting for install: x-over steering, dual 'cases, twin-stick, 3" body & drivetrain lift, rear springs up front Still need: rear springs, 35" MT's, bumpers/sliders 2001 F350 - 7.3 110k miles on WVO conversion now!
[Re: 4Crawler]
#695619
02/13/06 11:10 PM
Brilliant! <img src="/forums/images/graemlins/kewl.gif" alt="" /> That's exactly what I'm going to do. Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Sid
