4wd pulls after aussie install #696297 02/14/06 12:54 AM
toy94x4 Offline OP
I'm sure that it's just the need for an alignment being magnified by the locker. But after I installed the aussie up front the truck now pulls when I accelerate. I need to look at a few other things under there as well. I was just wondering if anyone else had this issue also. Something else I tried is the locking of one hub only, so I can drive in the snow and it pulls doing that as well. Kind of interesting, but makes sense that with one hub locked it pulls one way, and with the other locked, it pulls the other. Does anyone else use the one hub locked method who has a non-selectable locker up front, and is there a preferred side to lock?
1994 P'up, 22RE, K&N, LCE exhaust sys (header, cat, muffler, 2.25" pipe), 1" RB seat lift, 1" RB body lift, 1.5" rear lift via shackles, Rancho 5000's, 33" Pro Comp M/T's, 4.88's w/ Aussie lockers front & back
Re: 4wd pulls after aussie install [Re: toy94x4] #696298 02/14/06 01:06 AM
Talon84X4 Offline
I have aussies front and back, and don't have that problem. Don't think that the aussie in front should have any affect on pulling one way or the other when the hubs are unlocked, even when 4wd is engaged.
'84 PU low & slow
Central Valley Crawlers
Re: 4wd pulls after aussie install [Re: Talon84X4] #696299 02/14/06 06:04 AM
toy94x4 Offline OP
It only does it when the hubs are locked.
Re: 4wd pulls after aussie install [Re: toy94x4] #696300 02/14/06 06:17 AM
Digital_Aardvark Offline
are all the tires aired up the same? If one side had more pressure in it, it would be a slightly larger diameter and could cause pulling to one side
1989 3.0 5 spd extended cab with more rust than should be legally aloud, soon to have a D44 front and D60 rear
Re: 4wd pulls after aussie install [Re: Digital_Aardvark] #696301 02/15/06 01:41 AM
toy94x4 Offline OP
yeah, all tires the same. Like I mentioned before, I'm most certain that it's the need for an alignment being magnified. Either that or other worn out parts that I'll find soon as I get a chance to crawl underneath it. Thanks
Re: 4wd pulls after aussie install [Re: toy94x4] #696302 02/15/06 04:41 AM
trythis Offline
could it be that one of your wheels' hubs isn't locking?
Re: 4wd pulls after aussie install [Re: trythis] #696303 02/16/06 12:37 AM
toy94x4 Offline OP
don't think so, I locked each hub one at a time and they work correctly.
Re: 4wd pulls after aussie install [Re: toy94x4] #696304 02/16/06 01:34 AM
Talon84X4 Offline
alignment is the problem
the aussie if working correctly then there should be no side thats pulling more than the other as far as the drivetrain goes...can't say the same about alignment
my aussie up front does the opposite of what you describe it keeps the truck straight, very straight, and will try to keep it that way even during turns
'84 PU low & slow
Re: 4wd pulls after aussie install [Re: Talon84X4] #696305 02/17/06 03:48 AM
9
94krawler Offline
Mine too <img src="/forums/images/graemlins/notooth.gif" alt="" />
94 toy truggy rolling on tons
>>>>>>>>www.Rightcoast4x4.com<<<<<<<<
Rockcrawling for the eastcoast.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6263 MB (Peak: 0.7285 MB) Data Comp: Off Server Time: 2026-06-21 22:35:52 UTC
