oil/temp gauge recommendations - aftermarket... #696516 02/14/06 07:02 AM
84toyota Offline OP
I'm looking to buy one of Mosk's gauge pillars, which I'll put an oil pressure gauge and a temp gauge in... Does anyone have a brand that they'd recommend? I don't want to spend a ton of money, but want a quality gauge... Any ideas for the third gauge? Vacuum gauge? When installing an aftermarket temp gauge, where do you put the sensor? Do you replace one of the existing ones, or do you have to drill and tap a new hole? I'd like to leave the factory ones alone, because I'm not sure how much of the smog parts are triggered from the temp gauge...
Ken
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: oil/temp gauge recommendations - aftermarket... [Re: 84toyota] #696517 02/14/06 07:18 AM
kyle-22r Offline
autometer makes some nice units, and as for the temp gauge, i think that most 22Rs have at least one plugged bung on the intake manfold that you could stick another sender in.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: oil/temp gauge recommendations - aftermarket... [Re: kyle-22r] #696518 02/14/06 07:35 AM
4WD22R Offline
Ditto on the autometer gauges, and yes, the 22Rs do have a plugged bung, should be directly below your t-stat housing on the passanger side of the motor.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: oil/temp gauge recommendations - aftermarket... [Re: 4WD22R] #696519 02/14/06 07:45 AM
84toyota Offline OP
My intake manifold that I have installed actually doesn't have that plugged bung beneath the thermostat... there is nothing there but the cast manifold. I do have two other spare intakes which have that bung... One of the intakes has a BVSV in that location, which apparently operates the vacuum advance in some sort of way... something about when the temp heats up, the advance kicks in...
Ken
Re: oil/temp gauge recommendations - aftermarket... [Re: 84toyota] #696520 02/14/06 07:46 AM
84toyota Offline OP
One more decision - digital or analog gauge? What does everyone prefer?
Re: oil/temp gauge recommendations - aftermarket... [Re: 84toyota] #696521 02/14/06 08:13 AM
4WD22R Offline
I like analog, easier to see while driving, I think.....
The BVSV directs vacuum when it heats up, got some sort of metal valve dealie in there that's heat sensative.....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: oil/temp gauge recommendations - aftermarket... [Re: 84toyota] #696522 02/14/06 09:01 PM
MuddRunner Offline
I think that the temperature sender is only for the dash meter. The other temperature sensor in the front of the engine provides the signal for computer, i.e. cold idle etc. This is on my '92, maybe the same on your '84
'92 Pickup x-cab, 22re, auto.
'50 Ford Tudor Sedan, my new "Hot Rod"
Too much to do, too little time/$$$
Heb. 12.3
Re: oil/temp gauge recommendations - aftermarket... [Re: MuddRunner] #696523 02/14/06 09:15 PM
Buck Offline
Definately prefer Analog, can't stand digital gauges. As for manufacturer, probably have to go with Autometer, I have some Mallory gauges that I bought years ago and had in my 67 LeMans, but I don't think they make gauges anymore.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
84 Ext. Cab Pickup.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6232 MB (Peak: 0.7214 MB) Data Comp: Off Server Time: 2026-06-10 07:15:56 UTC
