Page 2 of 3 1 2 3
Re: how often should I "really" change my fuel filter? [Re: OOP'S] #696802 02/16/06 04:50 AM
On one of my prior 4Runner's I had the filter changed and there was some nasty black stuff coming out of it. I wasn't having any problems with the truck but it seemed like a good maintenance thing to do. I wouldn't do it too often but I think it needs to be done to keep the fuel injection running properly. My current 4Runner has 148K miles on it and I'm not sure if the original owner changed it or not. I need to check his records, he was good with the maintenance and I'm grateful.
Re: how often should I "really" change my fuel filter? [Re: OOP'S] #696803 02/16/06 03:11 PM
TimsToyo Offline
Considering that a fuel filter cost about $10 and a tow truck cost $150+, I'd change it about every 50K miles. But if you have a lot of trash in your tank you may have to change it more often.
FYI, for those few of us who have a fuel filter mounted under the hood, make sure the previous owner(s) didn't leave the original fuel filter installed at the tank (like mine did <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> ). If your filter has been moved just make sure it's installed on the ENTERING side of the fuel pump and not the LEAVING side. The filter needs to protect the pump.
'86 Toyo 4wd
'04 600RR
Re: how often should I "really" change my fuel filter? [Re: oldsub86] #696804 02/16/06 11:53 PM
smansfield Offline
i called toyota to price a gas filter,and the parts guy
asked me why i was pricing one,he said not to touch it.
1993 toy pickup xcab 4x4
Re: how often should I "really" change my fuel filter? [Re: smansfield] #696805 02/17/06 12:04 AM
4WD22R Offline
Am I missing something here? I thought it was a GOOD idea to change your fuel filter every now and then.....not a BAD thing........
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: how often should I "really" change my fuel filter? [Re: 4WD22R] #696806 02/17/06 02:22 AM
I think the fact that the PO failed to replace the fuel filter caused the in-tank fuel pump to fail on my 92 4Runner. When I purchased it, mine had over 145,000 mile on it. Eventually had to replace the fuel pump after replacing the filter. Replacing a pump is LOTS more expensive than replacing fuel filter. Same scenario happend on my mom's car, too. I don't care WHAT the dealer says,, replace it! Filters get stuff in them and eventually clog up. That's what they are supposed to do -- 'filter'.
Mike in AR
Re: how often should I "really" change my fuel filter? [Re: 4WD22R] #696807 02/17/06 02:26 AM
TimsToyo Offline
What did you tell him to make him say that? Low mileage?
I don't know of a filter that your not supposed to change.
Mike in AR
You're absolutely right! The more the filter loads up the harder the pump has to work to move the same amount of fuel. Eventually, it begins to starve the motor out on top end.
'86 Toyo 4wd
'04 600RR
Re: how often should I "really" change my fuel filter? [Re: TimsToyo] #696808 02/17/06 02:35 AM
Rodgertheshrubber Offline
mine was a huge pita to change, wish i had NEVER got into it. even at 130k miles, there was nothing wrong with the filer. if you do it, i would suggest getting the line that is forward of it too. there is a filter (mesh screen) that is attached to the pump, anyway. my .02
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
Re: how often should I "really" change my fuel filter? [Re: J94_4runner] #696809 02/17/06 02:39 AM
92 v6 truck. I changed mine out when I bought my truck with 130,000mi. It had never been done. I could hardly blow air through the old filter. Despite the massive restriction, I noticed no difference with the new filter. Our fuel pumps must be very powerful! I changed it again less than two years later and it was as clear as the day I bought it.
Re: how often should I "really" change my fuel filter? #696810 02/17/06 07:30 AM
4WD22R Offline
Sheesh.....I'm glad mine's a carbie! It sounds like changin fuel filters if fun for you other guys! It takes me about 15 mins to get mine done. Unclip filter from holder, undo 2 lines, throw away, install lines on new filter, clip back in, and drive away.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: how often should I "really" change my fuel filter? [Re: 4WD22R] #696811 02/17/06 03:03 PM
TimsToyo Offline
Exactly! Not sure what configuration the other models have but the '86 carb'd is simple. <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
'86 Toyo 4wd
'04 600RR
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6378 MB (Peak: 0.7581 MB) Data Comp: Off Server Time: 2026-06-15 10:32:06 UTC
