Page 1 of 3 1 2 3
Taller gears for my Gen1 Di-D. Help needed. #697642 02/17/06 11:43 AM
Boertjie Offline OP
Some of you are aware of my conversion, where I replaced the 4d56 (2.5TD) engine with a 3.2 Di-D diesel engine.
The conversion is a great success, except for the final drive gearing.
Currently I have 1:4.875 diff ratio, which is way to low for my application (90% on-road).
The Gen3 Di-D comes with 1:3.9 diffs, so I thought that would be about what I needed.
According to the Aussie site, the current diffs I have are as follows:
http://www.outerlimits4x4.com/PHP_M...amp;sid=5452dcf54a5c0d6ac448b1764b11cef5
Front: 7.25" dia (low pinion), 25 spline, 29mm diameter
Rear: 8" dia, 28 spline, 30.5mm diameter
I found this site, where they advertise 3.9 diffs for Monteros:
http://www.trademotion.com/partloca...ro&year=1989&catalogid=1
The problem is that the supplier cannot verify whether in fact it will fit my Pajero.
Does anybody have any info on the availability/suitabiliy of these 3.9 R&Ps?
1989 Exceed LWB
4m41 (3.2DiD TurboDiesel
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: Boertjie] #697643 02/17/06 02:02 PM
powerRam50 Offline
it looks like you have the 4 cylender size axles.the 3.909 gears for the trucks should fit your rig.
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: powerRam50] #697644 02/17/06 02:36 PM
Boertjie Offline OP
Poweram,
1. Which trucks? Remember we had different Mitsu models here in South Africa.
2. How available are the parts from breakers? Ring & pinion only?
3. Price (I will pay for freight).
4. Would you have Mitsi part Numbers?
Thanks so far.
1989 Exceed LWB
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: Boertjie] #697645 02/17/06 03:07 PM
powerRam50 Offline
breakers?is this a junk yard?basicaly all 4x4 dodge d-50's and mitsubishi mighty max trucks with the 2.6 came with the 3.909 gears.i know there are a few in the junk yards around here.i am sure someone here has the mitsu part number.my truck had the 3.909 gears but i got rid of those when i got my 4.625 gears out of a monty.
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: powerRam50] #697646 02/17/06 03:25 PM
Boertjie Offline OP
PowerRam,
Sorry,
In USA = junk yard
In UK = breaker
In South Africa = scrap yard
How easy would it be for you to source two second hand sets of Ring & Pinions (front & back), and at what price?
Mitsu Part nos?
1989 Exceed LWB
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: Boertjie] #697647 02/17/06 06:39 PM
powerRam50 Offline
last i knew there was a couple junk yards that had them.i will call and see.
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: powerRam50] #697648 02/17/06 06:56 PM
powerRam50 Offline
i just got off the phone with one place and they wanted 350 amarican for both and then there is another place that said he would give me a deal if i got both front and back.he said 200.
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: powerRam50] #697649 02/20/06 10:47 AM
Boertjie Offline OP
Powerram,
Sorry, I'm off air over weekends.
That sounds fantastic.
I will need front and read diffs' R&Ps.
Is there a way you can confirm that they are the sizes as per my original post? I would hate to pay for shipping etc. and find that they do not fit!
I am sure I can find a way of getting money to you once we can confirm that they will fit?
1989 Exceed LWB
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: Boertjie] #697650 02/20/06 02:37 PM
powerRam50 Offline
what year is your rig?
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: powerRam50] #697651 02/20/06 03:46 PM
Boertjie Offline OP
The Pajero is 1989 LWB (NG) of Japanese origin.
As I bought it:
Non-intercooled 2.5 TD engine (4d56)
Auto transmission
Leaf springs in rear
4:875 diff gears
1989 Exceed LWB
5-spd Manual Tranny
2" lift
31" BFG A/T
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6402 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-11-15 23:52:00 UTC
