add-a-leaf #697762 02/17/06 10:19 PM
blevcom21 Offline OP
hey im thinking about adding an add-a-leaf to the where'd it go rodeo what all do i need to buy for that i just bought a t-case and lockright for my samurai so the lift depends on total cost......i like wheelig the underdogs
<img src="/forums/images/graemlins/notooth.gif" alt="" />
if it don't fit, force it if it breaks, it needed to be replaced anyway
Re: add-a-leaf [Re: blevcom21] #697763 02/17/06 10:47 PM
Bigpoppax2 Offline
Usually just the add-a leaf kit, but some will suggest new U-bolts which isn't a bad idea.
Re: add-a-leaf [Re: Bigpoppax2] #697764 02/17/06 10:50 PM
RobG Offline
you'll need longer center pins, but usually add-a-leaf kits come with these.
-Rob
Re: add-a-leaf [Re: RobG] #697765 02/17/06 11:15 PM
yeah it comes with the center pins i just want to keep the total cost down or at least see how much it will cost
Re: add-a-leaf [Re: blevcom21] #697766 02/18/06 05:11 AM
CPOM Offline
I ran darlington's spring upgrades for a while and recommend them. It is a mini 3 leaf set you add to the bottom of your pack, replacing the overload. darlington-offroad.com
CHRIS
98 Amigo, 92 Pup
Re: add-a-leaf [Re: CPOM] #697767 02/18/06 06:09 AM
mhamari Offline
This is a probably a stupid newbie question, but how does an add-a-leaf work? Seems to me that adding leaves wouldnt help unless the springs are on top of the axle.
Mike Hamari
'89 Trooper
Re: add-a-leaf [Re: mhamari] #697768 02/18/06 06:14 AM
strawmyers Offline
Isuzu Moderator
Adds more arch to the spring pack.
I'll second the DOR springs upgradez... been running them for years on the Amigo. They'll run you more money; but, IMHO, its money well spent <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean Strawmyer
Re: add-a-leaf [Re: strawmyers] #697769 02/18/06 07:46 AM
maxwell417 Offline
I'll third the DOR springs upgradez... been running them for years on the Trooper.
I'm a lazy cut and paster <img src="/forums/images/graemlins/nana.gif" alt="" />
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: add-a-leaf [Re: maxwell417] #697770 02/18/06 12:01 PM
i was thinking of the independent4x springs for 50 bucks
this isnt my trail rig its my dd so it doesnt really need
all that much flex just more clearance then ill do a virtual lift or fender trim and put some 32's on it and call it a day. it already has 32x9.50s on it i just wanna go a little wider for a more agressive look
Re: add-a-leaf [Re: blevcom21] #697771 02/18/06 02:03 PM
Smiley Offline
Jack,
If it helps anyà
IÆve always wanted a set of DOR Spring Packs, but IÆve been running an Add-a-Leaf set-up since day one û and throughout all of the 4-wheeling IÆve done, IÆve only ever broken one of them (OK, and maybe a couple of spring pins <img src="/forums/images/graemlins/shiner.gif" alt="" /> )
...some will suggest new U-bolts which isn't a bad idea.
Yep û and I be one of those æsomeÆ <img src="/forums/images/graemlins/wink.gif" alt="" />
You should be able to get both the Add-a-Leafs & a new set of U-bolts for close to $100 û but if youÆve got some cash to spare, go ahead and spring for the DOR Packs.
(Yes û Pun intended <img src="/forums/images/graemlins/pfft.gif" alt="" /> )
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6414 MB (Peak: 0.7611 MB) Data Comp: Off Server Time: 2026-06-23 03:12:24 UTC
