Anybody watch extreme 4x4 on Sat., 02/18/06? #698128 02/19/06 12:41 AM
TrooperJ Offline OP
They had an old yota landcruiser in there today. They were doing a SOA conversion on the front axle. They had problems with setting up the caster on it, so they ground into the axle tube, heated the tube up, put a pry-bar in the birf cup and twisted it to give them the caster they needed then welded up the ground parts. Now, is it just me, or does that seem like a little bit of booty fab, and something that doesnt seem very structuraly sound? Is it common?
Just curious...
-J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
Re: Anybody watch extreme 4x4 on Sat., 02/18/06? [Re: TrooperJ] #698129 02/19/06 02:13 AM
Adam F Offline
I saw it.
It's called a cut and turn. Nothing booty fab about it. Most people dont do it because they eitehr dont know about it or dont have the skills to do it.
97 4R, stock, daily driver
Re: Anybody watch extreme 4x4 on Sat., 02/18/06? [Re: Adam F] #698130 02/19/06 02:33 AM
Yeah i watched it i wish they would do some shows on Jeeps more often
Re: Anybody watch extreme 4x4 on Sat., 02/18/06? #698131 02/19/06 03:23 AM
TrooperJ Offline OP
They dont do enough shows on jeeps? 2 of the project trucks they are working on are jeeps!
I guess there is more than one way to skin a cat, and i guess more than one way to correct caster. Thats an interesting piece of trivia to know...
Re: Anybody watch extreme 4x4 on Sat., 02/18/06? [Re: TrooperJ] #698132 02/19/06 10:20 PM
Adam F Offline
Whats the other way to correct caster on a Toyota axle? Shims? With cutting and turning, you can set the pinion at whatever angle you want, and have the correct caster. You can't do that with shims.
If your doing a SOA, then you would be stupid NOT to cut and turn, since you are already doing half the work that mini truck owners would have to do (cut and reweld spring perches)
You don't see it in the minitruck world a lot because all minis are sprung over, where as land cruisers are sprung under, and a SOA is common for them.
The birf cups at the end of the Toyota axle have a tube connected to them that is sleeved by the outer housing. So all they are doing is cutting through the OUTTER housing weld, and turning the inner sleeve, and rewelding it.
Here's a good link about a cut and turn
http://www.ih8mud.com/tech/soa/5.html
Re: Anybody watch extreme 4x4 on Sat., 02/18/06? [Re: Adam F] #698133 02/19/06 10:54 PM
TrooperJ Offline OP
Ok, that image, and your description cleared it up for me. See, the reason i thought it was "booty-fab" was because i thought they were simply weakening the metal by grinding it, heating it up, and then forcing the entire axle tube to twist. Now i see that they are twisting just a small portion of the tube, one that is completely free of the rest of the axle tube. My thoughts were that they would be weakening the axle tube by heating it so much that they could freely bend it.
I understand better now. Thank you. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Anybody watch extreme 4x4 on Sat., 02/18/06? [Re: TrooperJ] #698134 02/19/06 11:44 PM
Talon84X4 Offline
i'm a late reply, i had to record it, saturdays i usually don't wake up in time to see it, and still havn't gotten to watch it...... <img src="/forums/images/graemlins/frown.gif" alt="" />, too much homework
'84 PU low & slow
Central Valley Crawlers
Re: Anybody watch extreme 4x4 on Sat., 02/18/06? #698135 02/24/06 03:58 PM
BigSwede Offline
You have got to be kidding me...have you paid attention at all? What about Cheap Jeep? Project AJ?
And anyway, thank God they are willing to do something different than the dime-a-dozen, cookie-cutter Jeep projects all the time... <img src="/forums/images/graemlins/smile.gif" alt="" />
Serenity now!
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6228 MB (Peak: 0.7180 MB) Data Comp: Off Server Time: 2026-06-07 05:01:59 UTC
