Brake indicator light comes on #698168 02/19/06 01:41 AM
I
irsean Offline OP
Brake shoes and pads are fairly new (lots of material left on them). Plenty of fluid (probably could be changed).
Why would the brake indicator light (dash) keep coming on?
1993 4Runner SR-5 4WD V-6 Auto Trans
1990 Pick-up (Hilux) 2WD SR-5 V-6 Auto Trans
Re: Brake indicator light comes on [Re: irsean] #698169 02/19/06 02:19 AM
kewlynx Offline
Presuming your fluid level is okay and the switch in the cap is okay, check your alternator belt; possibly brushes worn as well.
Yota just wired it up that way!
**ubi apis- ibi salus**
Re: Brake indicator light comes on [Re: kewlynx] #698170 02/19/06 02:21 AM
I
irsean Offline OP
Alternator affects brake light?
Re: Brake indicator light comes on [Re: irsean] #698171 02/19/06 02:24 AM
kewlynx Offline
That's how it got wired, even in my truck; brake/charge lights usually come on at the same time if the charging circuit is failing. Only other thing I can think of is your ebrake not being fully retracted.
Re: Brake indicator light comes on [Re: kewlynx] #698172 02/19/06 03:55 AM
I
irsean Offline OP
The light doesn't come on fully. It comes on in a varied dimness and sometimes goes off completely. What about the switch?
Re: Brake indicator light comes on [Re: irsean] #698173 02/19/06 03:57 AM
Adam F Offline
Is it both battery and brake light? If so, yes those are wired together when the alternator is failing.
Here's the fix
www.4x4wire.com/toyota/maintenance/alternator_brushes/
97 4R, stock, daily driver
Re: Brake indicator light comes on [Re: irsean] #698174 02/19/06 03:59 AM
Nix_Toy Offline
That happened in my 98 Tacoma a few years back... Because it was dim, and/or dimming, it was directly linked to the cluster... the R+R the cluster and all was fine.
-Nick
Re: Brake indicator light comes on [Re: Nix_Toy] #698175 02/19/06 05:09 AM
The fluid level float in your brake master cylinder has a small hole in it ( from miles of sloshing ). It has some fluid in it now, and it is gradually sinking. Disconnect the wires from the brake fluid reservoir cap and see if it stops coming on.
This solution really eluded me for a long time. Everytime the light would flash, it would kick the cruise control off,, if I had it set.
Mike in AR
Re: Brake indicator light comes on #698176 02/22/06 01:25 AM
I
irsean Offline OP
Thanks Mike. That was it. The Floater was filled with fluid. Disco'd the connection and light went away. Got a new cap and float. Problem solved.
This site is indispensable.
Re: Brake indicator light comes on [Re: irsean] #698177 02/22/06 02:22 AM
Yer Welcome! I guarantee the posters on this board have helped me lots more often than I've helped them.
BTW -- How much was the replacement cap / float and where did you finally get one? I never pursued replacing mine.
Mike in AR
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6336 MB (Peak: 0.7559 MB) Data Comp: Off Server Time: 2026-06-10 07:14:06 UTC
