Brake Rotor! #698238 02/19/06 04:11 AM
4WD22R Offline OP
Today I went about putting on new CV axels, and decided I'd also replace the disc rotor because it was WAAAAY beyond the point of being turned....pretty much unsafe <img src="/forums/images/graemlins/scared.gif" alt="" /> Everything went pretty good 'cept for FUBARing the inner seal on the hub, oh well new one tomorrow morning. My question is this: how do I seperate the hub from the rotor? I soaked the dang thing in PB but it ain't movin. Tried drilling through but I killed 2 drill bits and I ain't even through one bolt yet!! <img src="/forums/images/graemlins/confused.gif" alt="" /> Whats the trick here, I feel like I gotta be missin somethin.
Thanks!!
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Brake Rotor! [Re: 4WD22R] #698239 02/19/06 04:17 AM
kewlynx Offline
The lockout hub? Or the rotor from the spindle assembly?
http://www.4x4wire.com/toyota/maintenance/front_end/
**ubi apis- ibi salus**
Re: Brake Rotor! [Re: kewlynx] #698240 02/19/06 04:23 AM
4WD22R Offline OP
If your truck is IFS or an early solid axle (1979-1980) removing and replacing rotors is an easy task. Remove the 6-14mm bolts from the back side of the wheel hub, and pull the rotor off of the wheel hub. Replacing the rotor is just as easy, but be sure to clean any debris off the wheel hub first, so that you are sure the rotor is sitting flush on the wheel hub.
HA! Riiiiight.
Mine are completly rusted/siezed to the hub <img src="/forums/images/graemlins/angry.gif" alt="" />
O, spindle assembley. <img src="/forums/images/graemlins/lol.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: Brake Rotor! [Re: 4WD22R] #698241 02/19/06 07:48 AM
missouriman Offline
take them to a shop, I am pretty sure that you have to press out the lug studs as well as the 14 mm bolts on the back.
Re: Brake Rotor! [Re: 4WD22R] #698242 02/19/06 04:30 PM
BennyBoy Offline
On my 91 I had some bolts to undo and I used a 10lb. beater to help it along.
Might be a good time to upgrade to >93 v6 brake system.
Re: Brake Rotor! [Re: BennyBoy] #698243 02/19/06 05:17 PM
willzrunna96 Offline
take the inner 6 bolts from rotor to hub out and then put the the rotor on a block of wood and woond on top of the hub and smash itit will come right off
Re: Brake Rotor! [Re: 4WD22R] #698244 02/19/06 07:23 PM
Adam F Offline
The EASIEST way is to simply unbolt the 6 bolts holding the rotor to the hub, and drive a pickle fork in between the rotor and the hub.
97 4R, stock, daily driver
Re: Brake Rotor! [Re: Adam F] #698245 02/20/06 06:48 AM
4WD22R Offline OP
Thanks guys, I got it off, for some reason it didn't want to come off for me, soaked her in PB over night and attacked with a ratchet and a rubber mallet and we're in buisness <img src="/forums/images/graemlins/smile.gif" alt="" />
On a side note, it looks like someone put V6 calipers on it before I got the truck, sweet!!
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6244 MB (Peak: 0.7229 MB) Data Comp: Off Server Time: 2026-05-25 20:02:55 UTC
