What the hell is this?? (Carburetor issues) 22R
#698319
02/19/06 04:09 PM
On my 100th inspection of this carburetor I noticed that there appeared to be a plate missing from the drivers side. Upon consulting the FSM I confirmed that there should be a plate and a couple of other pieces. My question is what is this and what is it's function? ![[Linked Image]](http://img71.imageshack.us/img71/576/untitled8hv.jpg) This carb has run rich as hell (16mpg) since I got the truck but I've been dealing with vacuum leaks, EGR valves, clogged CAT/muffler, and loose plugs in the head just to name a few. Timing appeared to be at 2? last night but I was tired so I'll recheck it today. The plugs are gapped at 0.041in for some reason. I'm wondering if someone is trying to compensate for other problems by running the plugs hotter instead of fixing the real issue. I'm also checking the coil today. If everything else checks out I'm going to need some help in pinpointing the problem with the carb.
'86 Toyo 4wd '04 600RR
Re: What the hell is this?? (Carburetor issues) 22R
[Re: TimsToyo]
#698320
02/19/06 04:21 PM
I beleive only '84 and prior carbs have that plate you are referring to. Forget what it was for, but I've ran three carbs in the past two years and the only one that gave me issues had that plate <img src="/forums/images/graemlins/lol.gif" alt="" />
16mpg? Thats about average for me in the three warmer seasons.. I'd love to get that in the winter. I have stock gears and 33x12.5's. If your lifted, I'd say thats about right, if your stock, then thats probably a few mpg's low.
-Scerb
[Re: Scerb]
#698321
02/19/06 04:42 PM
Well maybe someone knew something I don't about that little plate. But the truck is all stock. No lift or different gears. And remember, we don't really have "winter" down here. <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: TimsToyo]
#698322
02/19/06 07:01 PM
On my 100th inspection of this carburetor I noticed that there appeared to be a plate missing from the drivers side. Upon consulting the FSM I confirmed that there should be a plate and a couple of other pieces. My question is what is this and what is it's function? ![[Linked Image]](http://img71.imageshack.us/img71/576/untitled8hv.jpg) This carb has run rich as hell (16mpg) since I got the truck but I've been dealing with vacuum leaks, EGR valves, clogged CAT/muffler, and loose plugs in the head just to name a few. Timing appeared to be at 2? last night but I was tired so I'll recheck it today. The plugs are gapped at 0.041in for some reason. I'm wondering if someone is trying to compensate for other problems by running the plugs hotter instead of fixing the real issue. I'm also checking the coil today. If everything else checks out I'm going to need some help in pinpointing the problem with the carb. Donno about the mileage but this is the part you were asking about.
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
[Re: TimsToyo]
#698323
02/19/06 07:05 PM
i think you should be getting better than 16 mpg in florida even when its winter. currently im getting 19.5 mpg almost consistently w/ half city driving and half highway driving. on straight highway i get about 24.5 mpg. i have 33's and 4.88 gears. i also have a carb.
[Re: TimsToyo]
#698324
02/19/06 07:19 PM
Look where that plate would go, without getting yourself hurt, put your finger in the little hole where that plate would go. If you feel vaccumm, you have a problem. 99% likely that it is plugged.
I've worked on many many carb. The only one that gave me alot of grief was one with that plate installed.
1986 Toyota 4x4 22wEBer Ported EB Offroad H/O Head "Josh Cam" Ported Intake & Weber38mm Carb LCE Header & 2.25in Exhaust RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
[Re: TimsToyo]
#698325
02/19/06 07:35 PM
I believe that device you have circled is what they call an over-run valve.
It leans the mixture by introducing air into the mix when the engine is decelerating with some load, like going down a grade still in gear with your foot of the gas pedal.
I believe they abandoned that idea on later carbs of the same model, they just left the casting boss on the side of the carb un-machined.
Just check to see if there is an open hole inside, if it's one that was abandoned it will be blank.
Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
#698326
02/19/06 07:54 PM
Thanks for the info guys! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Well looking at it last night it had threaded screw holes and what looked to be a functioning hole/port. I didn't see if it was drawing vacuum. I just sealed it up for now.
I did however re-time the motor back down 2-3? to stock. That seemed to have made a big improvement all around. Drives better and doesn't appear to be running near as rich.(My eyes aren't burning in the garage anymore! <img src="/forums/images/graemlins/lol.gif" alt="" /> )
Last question(s): Why would someone have the spark plug gap set at 0.041in? Is anyone else running that hot of a gap on a stock motor?
[Re: TimsToyo]
#698327
02/19/06 08:03 PM
Last question(s): Why would someone have the spark plug gap set at 0.041in? Is anyone else running that hot of a gap on a stock motor? By opening the gap you force the ignition coil to build a higher voltage potential and the larger gap between the center electrode and the ground bar allow better access to the air fuel charge. Only works on high end ignition systems where the coil has a greater energy potential. you may want to try going back to the factory recommend gap and see if that helps any. probably won't have much effect. Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
#698328
02/19/06 08:16 PM
That's what I was thinking. It still has the stock coil and as far as I know the stock cam and heads. But I don't have much history on this thing so who knows why they did what they did? <img src="/forums/images/graemlins/confused.gif" alt="" />
I'll re-gap and see what a difference that makes. So far all of my changes have had good results. <img src="/forums/images/graemlins/cheers.gif" alt="" />
