4.3 Vortec swap for Amigo #698394 02/19/06 09:22 PM
Hello again guys:
Here I go again. I can never leave things well enough alone. I'm making plans again to pull out my 2.6L, and install a 4.3L Vortec. Has anyone here had experience with the process, and/or can you point me in the right direction. I've spent a little time searching in the Isuzu archives, but can't seem to get a hit.
Here is what I have in equipment:
95 Chevy 4.3L Vortec
95 4L60E that came with the above motor
Dana 300 Xfer case.
I'd like to stick to the 4L60E because I'd still like a little economy when I decide to drive the vehicle long distances. On occasion I still us it as a daily driver. The Dana 300 seemed like a no-brainer because if it's durability and gearing.
I still have an IFS up front, but I'm unsure if the motor will clear the diff.
Any input guys?
Best regards,
Roberto Dean
Re: 4.3 Vortec swap for Amigo #698395 02/20/06 01:12 AM
http://www.off-road.com/isuzu/v6trooper.html
I'm unsure if it would clear the stock diff... there is quite a bit of clearence with the 2.6, and I don't think it would be a problem. A body lift and a higher mounted engine would solve that problem. But would also raise the center of gravity.
Re: 4.3 Vortec swap for Amigo #698396 02/20/06 01:17 AM
strawmyers Offline
Isuzu Moderator
Stinkbug on this forum has the same engine swapped into the same vehicle. Same t-case as well; but a 700R4 between the two instead of a 4L60E.
Sean Strawmyer
Re: 4.3 Vortec swap for Amigo [Re: strawmyers] #698397 02/20/06 09:54 AM
StinkBug Offline
Yep I did the same swap. My 700R4 is the same tranny as a 4L60e but without the electronic controls. I dont know if the motor will fit around the stock front end, as I did a SAS at the same time. If you push the motor far enough back against the firewall You'll be able to run a stock fan and clutch up front with the radiator in the stock location. My distributor rubs the firewall, but I found out you can still fit everything with the motor another inch forward. You will have to take a BFH to the passenger side floor in a couple spots, but nothing too disgusting, also you'll wanna use stock S10/Blazer manifolds as they are the only ones I found that fit between the frame rails. Good luck.
Dallas
[color:"blue"]Crew Chief, RedBull RockCrawling Team [/color]
[color:"red"]StinkyFab Custom Metal Creations[/color]
Project StinkBug
Re: 4.3 Vortec swap for Amigo [Re: StinkBug] #698398 02/20/06 11:13 AM
Rodeo Guy Offline
The vortec engines started in 96, you sure thats what you got?
Sounds like a fun project <img src="/forums/images/graemlins/kewl.gif" alt="" />
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: 4.3 Vortec swap for Amigo [Re: Rodeo Guy] #698399 02/20/06 12:52 PM
Y
ybnormal70 Offline
1988 - 4.3 L Vortec 4300 V6, TBI, 150 hp (112 kW)/230 ft.lbf (312 Nm) (VIN Z)
1989-1992 - 4.3 L Vortec 4300 V6, TBI, 160 hp (119 kW)/230 ft.lbf (312 Nm) (VIN Z)
1990-1993 - 2.5 L Tech IV I4, TBI, 105 hp (78 kW)/135 ft.lbf (183 Nm) (VIN A)
1992-1993 - 4.3 L Vortec 4300 V6, CPFI, 195 hp (145 kW)/260 ft.lbf (353 Nm) (VIN Z)
1994 - 2.2 L L43 I4, MPFI, 118 hp (88 kW)/130 ft.lbf (176 Nm) (VIN 4)
1994 - 4.3 L Vortec 4300 V6, CMFI, 195 hp (145 kW)/260 ft.lbf (353 Nm) (VIN W/Z)
They have had different versions of the 4.3 since 1988. I had a 1994 Blazer with one and they were in alot of older S-10's.
L8r,
Kevin
'94 Trooper S 3.2SOHC, 5spd, Aisin hubs, OME919 w/ 2" coil spacers, Edelbrock shocks, fliped BJ's and spacers, 15" snowflakes w/33x12.50x15
Re: 4.3 Vortec swap for Amigo [Re: ybnormal70] #698400 02/20/06 02:07 PM
Rodeo Guy Offline
Alright I stand corrected. I think it might be, the vortec v6 only came in s10s/blazers before 95, not the full sizes, which I was looking at.
Mike
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6123 MB (Peak: 0.7067 MB) Data Comp: Off Server Time: 2026-11-01 20:17:29 UTC
