Alternator Question, any suggestions? #698412 02/19/06 11:02 PM
x1racer Offline OP
'93 SR, 133k. I bought it last fall and replaced:
T-belt
all tensioners
acc. belts
H2O pump
ignition stuff
It runs like a champ, low oil consumption, no smoke (yet). Previous owner had just replaced the alternator (POS Bosch reman).
Problem: Every few weeks all the lights will fluctuate intensity at ~ 4hz with accompanying slight siren whistle from alternator. I've "fixed" it three times now by futzing with the hot line connections between alternator and battery, but it keeps coming back. Lots of searching concludes the fluctuation is charge current going un-damped from the alternator straight to the electrical system rather than charging the battery.
Anything else I should try before junking the alternator? Battery is charging fine and I've had no problems with that.
<img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks in advance!
'93 Montero SR, bone stock for now
'92 Porshe 911 Turbo project car
Re: Alternator Question, any suggestions? [Re: x1racer] #698413 02/19/06 11:20 PM
NathanC Offline
All I'll suggest is check your grounds from the battery. I've had some pretty wierd stuff happen resulting from poor grounds. It is something that is very easy to overlook. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: Alternator Question, any suggestions? [Re: NathanC] #698414 02/20/06 08:28 PM
x1racer Offline OP
Thanks Nathan, I have experience with bad grounds. Pulling the motor on my '89 Carrera was so easy I pulled it for valve adjustments! But the block strap decided to pass the starter current on to the 18g horn ground <img src="/forums/images/graemlins/scared.gif" alt="" /> after one pull. (poof!)
Re: Alternator Question, any suggestions? [Re: x1racer] #698415 03/01/06 03:34 AM
BMT213A Offline
Thanks in advance!
Your alternator is about to fail.
I'm up to reman unit#5 (love those lifetime warranties...). The symptoms you describe happened to me before unit#2,3 quit. #1, #4 failed in more dramatic fashion.
My theory: Reman units can't cope with being so close to the header and getting hot. My next step is a used OEM unit.
Paul
Re: Alternator Question, any suggestions? [Re: x1racer] #698416 03/01/06 07:16 AM
LRJ4x4 Offline
reman units <img src="/forums/images/graemlins/barf.gif" alt="" />
I'm not familiar with your exact truck but check to make sure there is not a heat shield missing.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.005s) Memory: 0.6068 MB (Peak: 0.6722 MB) Data Comp: Off Server Time: 2026-06-22 06:13:54 UTC
