Page 2 of 3 1 2 3
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698451 02/25/06 04:50 AM
OOP'S Offline
Have you checked the gasket-mating surface of the block? Make sure there are no gouges, dents, or an irregularity to the surface
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698452 02/25/06 09:51 AM
4WD22R Offline
My '86 22R regularly hits almost 75psi, and no problems yet, I wouldn't thing that 50 psi is bad.....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Oil pressure blowing out filter gaskets?! [Re: 4WD22R] #698453 02/25/06 01:56 PM
87Toy4x4 Offline
yeah mine goes over 80 psi regularly. ive never heard of more oil pressure being bad.
Re: Oil pressure blowing out filter gaskets?! [Re: 87Toy4x4] #698454 02/25/06 03:16 PM
P
poncho Offline OP
thanks for the input guys we'll give it another shot wish us luck
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698455 02/25/06 04:03 PM
Manson Offline
36 to 71 lbs at 3000 is what the manual says. If you are blowing gaskets at 50 psi then you have a cheap filter or damaged sealing flange.
Re: Oil pressure blowing out filter gaskets?! [Re: Manson] #698456 02/25/06 04:15 PM
CJM Offline
this may sound stupid , but I have seen it before.
same thing was happining to a guy up here , and we found that there was an old oring that was "glued" to the oil filter mounting surface . when he put on a new filter , it was on top of the "glued" gasket .... oil would blow out ... he did this twice ...
you might just check your oil filter mount surface for damage .
83 Trekker SR5
NEW Trekker forum
Re: Oil pressure blowing out filter gaskets?! [Re: Manson] #698457 02/25/06 05:32 PM
P
poncho Offline OP
the gauge we used went to 85psi and it pegged out. the worry we have now is whether th oil pressure is to the point to where it will cause the journal surface to score forcing them against the bearings rather than I know to much pressure will do that too. Rather than having that thin layer of oil in between.
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698458 02/25/06 05:37 PM
P
poncho Offline OP
gasket surface is fine no damage or deformities. smooth as glass
Re: Oil pressure blowing out filter gaskets?! [Re: CJM] #698459 02/25/06 05:42 PM
P
poncho Offline OP
right now nothing is stupid and everything that is said will be done and tried I am out of options short of taking the engine back out put bullet into the block and start with another one that is where I am at right now. I have been fighting to get this started for over a month and no luck as of yet. but to much oil pressure is a problem as of now so anything said will be taking seriously into consideration and tried.
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698460 02/25/06 08:43 PM
What grade oil are you running, 10w30 etc?
On a high volume oil pump you can see anywhere from 75-90 psi @ the upper rpm range.
The only other possibility I can think of other than tight bearing clearances would be the timing chain dampener which has a bleed off hole that lubes the chain by squirting oil out onto the lower portion of the chain.
This bleed off hole also prevents over tensioning of the timing chain which will wear down the plastic wear pad prematurely.
The dampener is not a tensioner, it's just controls (dampens) the slack side of the chain.
If you used an RTV silicone sealant when you installed the chain dampener and blocked up the oil feed to the dampener with the RTV then that would cause a rise in the oil pressure, but there would be some chain noise because the chain wouldn't be dampened properly.
Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6359 MB (Peak: 0.7596 MB) Data Comp: Off Server Time: 2026-06-07 05:39:51 UTC
