1982 CJ7 Laredo Straight 6 -help me out please- #698700 02/20/06 04:07 AM
2000ute Offline OP
I need to know what axles are under this puppy stock along with gearing.
If anyone can throw in some good aftemarket links, that would be appreciated too!!
Thanx!!
Used to have a custom 2000 Montero Sport - Front & Rear bumpers, Sliders, Warn m8000, 33/1050/15 BFG MT's
Now own a 1998 Toy 4Runner 3.4 Limited stock
Re: 1982 CJ7 Laredo Straight 6 -help me out please- [Re: 2000ute] #698701 02/20/06 04:45 AM
JeePete Offline
Well the first part is easy, Dana 30 front, AMC 20 rear, should be wide track. Ratios vary, 2.73,3.31,4.10? There is/was a tag on the dana with the ratio but they are rarely there and readable on a Jeep that old. Numbers stamped on the AMC 20 can be deciphered to tell the ratio but you will have to find the codes. My 86 Laredo came with 3.31 gears. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Oh, here's the codes.
Wide Track AMC 20
Code Gear Ratio Diff Type
D 2.73 Open
DD 2.73 Trac-Lok
B 3.31 Open
BB 3.31 Trac-Lok
A 3.54 Open
AA 3.54 Trac-Lok
H 3.73 Open
HH 3.73 Trac-Lok
C 4.10 Open
CC 4.10 Trac-Lok
The code is stamped on the housing boss to the left of the diff cover right near the axle tube.
Re: 1982 CJ7 Laredo Straight 6 -help me out please- [Re: JeePete] #698702 02/20/06 04:49 AM
2000ute Offline OP
Well the first part is easy, Dana 30 front, AMC 20 rear, should be wide track. Ratios vary, 2.73,3.31,4.11? There is/was a tag on the dana with the ratio but they are rarely there and readable on a Jeep that old. Numbers stamped on the AMC 20 can be deciphered to tell the ratio but you will have to find the codes. My 86 Laredo came with 3.31 gears. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Thanks man. I realise now that this is the wrong forum as I read the FAQ at the top of the tech forum and the link is great.
This one is totally stock and in great condition. Barely any rust, nothing is broke, all stock. It's my B inlaws rig and we'll go looking for stamps to determine the ratio.
Dude thanks!! You are the man!!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5928 MB (Peak: 0.6464 MB) Data Comp: Off Server Time: 2026-06-09 10:03:14 UTC
