Tire size question for OEM wheels #698936 02/21/06 03:07 AM
Squeezer99 Offline OP
standard with 215/75/R15 tires, which is what I have on my T100 right now. Although when I put heavy loads in my bed the rear tires buldge (they are rated for 1742 lbs each tire, but even when I only have 500lbs or so in the bed the tires start bulging and I can feel the rear end getting sloppy on corners)
Looking on tirerack, there was an optional 235/75/R15 tire size. Did T100's with the 235 sized tires use the same wheel as the 215 sized tires, or did they come with a wider factory wheel?
I'm asking because 235/75/R15's have a larger weight limit per tire. So with those I can put larger payloads in the bed before the handling gets sloppy.
Re: Tire size question for OEM wheels [Re: Squeezer99] #698937 02/21/06 03:47 AM
H2O_MAN Offline
31x10.5x15 LT should do the trick.
Re: Tire size question for OEM wheels [Re: Squeezer99] #698938 02/21/06 05:13 AM
surlynkid Offline
what size are your rims? teh 4x4 with 31x10.50 got a 15x7.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Tire size question for OEM wheels [Re: surlynkid] #698939 02/21/06 05:36 AM
L
lawnmowerman Offline
I just bought 4 BFG AT 265/75R-16's E load range(8ply).I carry a popup camper that weighs 700lbs empty and although that is not much I still like the security of an E rated tire.Install a set of Airlift airbags and you will be good to go.An oil cooler if you have an auto trans would be a good idea too.
Re: Tire size question for OEM wheels [Re: surlynkid] #698940 02/21/06 05:52 AM
no clue what my rim size is. its whatever the OEM steel wheels are. my T100 is 2wd. not sure what 31x10.50 means. my T100 is a 4cyl 5sp.
I just wanna know if on the OEM steel wheels that come with 215/75/R15 tires, if 235/75/R15 will fit on them, so that I can haul heavier payloads without the tires bulging.
Re: Tire size question for OEM wheels [Re: Squeezer99] #698941 02/21/06 06:11 AM
hupptoy Offline
Yes the 235's will fit the OE wheels.
With that said, what tire pressure are you running and what is the max pressure of your tires? The tire load rating is usually at max pressure, so if you haven't tried increasing the tire pressure to accomodate additional load, you may want to give that a try 1st.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: Tire size question for OEM wheels [Re: hupptoy] #698942 02/21/06 08:21 AM
thecat Offline
I have a 96 4x2 sr5. Stock size is 235/75/15 but I run bfg's 255/70/15.
Toyota master
Re: Tire size question for OEM wheels [Re: hupptoy] #698943 02/21/06 03:35 PM
235's will fit on the OEM steel wheels taht came with 215/75/R15's? awesome, I'll be buying 235/75/R15's next time around smile
the person asking about my tire pressure. normally I run 35psi in them but the max on the sidewall is 44psi. i run 35psi because at 44psi I'm worried that i'll wear out the center of the tire because of overinflation.
Re: Tire size question for OEM wheels [Re: Squeezer99] #698944 02/21/06 03:47 PM
Brian_M Offline
Don't be worried... at the proper load rating, the tires will have the right flex and contact with the road. I Always up my tire pressure when hauling anything substantial (better that than overheat the sides with excessive flex ~ the bulging you see ~ and cause weakness there that has been linked to blowouts).
I haven't checked lately, but my tires rarely have even 1/32rd of difference between inside, center and outside for tread depths (running at a range of pressures depending on the task at hand).
Cheers,
Brian M
'97 T100 SR5 4x4, with Buckets
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6277 MB (Peak: 0.7305 MB) Data Comp: Off Server Time: 2026-06-07 05:58:58 UTC
