Front Driveshaft angle #699066 02/21/06 06:15 AM
jmsdad Offline OP
My vehicle specs:
86 SAS 4Runner with 83 toyota rear springs up front. 2.5" drop hanger. 5.5" shackles. Dual case setup with Marlin crossmember/skidplate. Low pinion elocker in front axle. U-joint shaft with long slip.
I've put about 250 easy miles on the rear to break the new gears in. No death wobble with this setup. Just a slight shimmy @ 40mph. Don't know caster angle because I haven't taken it in to the alignment shop yet.
So, today I disconnected the rear shaft so I can run it in FWD to break in the front diff gears. With the steep angle on the t-case flange, I can only go 10mph max--pushing it with lots of vibes.
Without cutting/rotating the knuckles, will shims fix the angles? Here are some pics...
Too much angle on the t-case flange u-joint...
Re: Front Driveshaft angle [Re: jmsdad] #699067 02/21/06 06:28 AM
Brian894X4 Offline
Do you have a CV on the front driveshaft? If not, I'd do that. But a clearanced CV on there and you should be good to go.
Re: Front Driveshaft angle [Re: Brian894X4] #699068 02/21/06 07:18 AM
4Crawler Offline
You can use shims to correct the pinion angle up to the steering caster angle limit. You would need to see where your caster angle is now in order to see how much correction room you have:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
Assuming the truck is driven on the street, good steering would be more important than pinion angle.
Re: Front Driveshaft angle [Re: Brian894X4] #699069 02/21/06 08:00 AM
jmsdad Offline OP
[color:"red"]No CV. Just U-joints at both ends. I think a CV at the tcase end would work, but I know there will still be vibrations. At this point, I'm looking for the cheapest fix-and that's shims.
[/color]
[color:"red"]Truck is driven on the street daily. I'll get back with you in a few days after I get my caster angle. [/color]
Re: Front Driveshaft angle [Re: jmsdad] #699070 02/21/06 08:23 PM
anthony1 Offline
You need one of these...
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Front Driveshaft angle [Re: anthony1] #699071 02/21/06 09:52 PM
to compensate for the angle, you have 3 choices:
drivetrain lift to lessen the angle of the t-case flange
CV driveshaft
degree shims
honestly, the degree shims will probably not get you anywhere near where you need to be, plus to match the backward sloping angle of the t-case flange, you would need to point the pinion to the dirt.
i would go with the CV shaft.
otherwise, deal with it. if your truck is low speed wheeling only, its not a big deal. i have a similar setup but with a single t-case and i run std. u-joints at both ends.
for proper gear break-in, swap the front and rear 3rds
Re: Front Driveshaft angle #699072 02/21/06 11:10 PM
anthony1 Offline
I don't think you mean to say drivetrain lift as in make the t-case higher right? ...In his case, it would be drivetrain drop. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Front Driveshaft angle [Re: anthony1] #699073 02/21/06 11:58 PM
4Crawler Offline
You can affect the t-case flange angle a bit if you raise just the t-case end (leaving the egine at stock height). About 1 degree of angle for each inch one end is lifted relative to the other. This will affect both front and rear flanges, lowering the front angle and increasing the rear angle.
Re: Front Driveshaft angle [Re: 4Crawler] #699074 02/22/06 01:05 AM
jmsdad Offline OP
I don't have a body lift on my truck. Looking under the drivetrain tunnel, there's less than 1" before the top of the T-case hits the cab. Also, my rear end is dialed in and I don't want to mess with angle. Even if I wanted to, I can't without a body lift or new crossmember.
So, I think I'll put a CV on. First, gotta clearance the IFS CV and take it in to get it weld on.
Off topic--The passenger seat bracket cable assembly broke today. It finally let go after 20yrs of use. Local prices were from $40 to $50 without the nearly 9% tax. Just ordered one from 1sttoyotaparts for $30 shipped. Couldn't be happier. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Front Driveshaft angle [Re: anthony1] #699075 02/22/06 05:29 PM
nope i said what i meant. if we were talking the rear d-shaft, a drop would lessen the angle. since we are talking the front, a t-case lift will lessen the angle since from the factory, the drive train goes downhill as you go rearward.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6411 MB (Peak: 0.7674 MB) Data Comp: Off Server Time: 2026-07-13 12:31:25 UTC
