Page 1 of 4 1 2 3 4
d35 vs d44 #699081 02/21/06 12:19 PM
i have a 97 tj sport with d30/35 f/r axles with 3.07's in them. i want to run 33's but am having a hard time deciding what to do. i want to improve my axle strength and add lockers within a year or so.
do i drop money into regearing the current axles and add the super 35 kit? or do i try and swap the rear axle with a d44 from an xj that has a better gear ratio, add a detroit and regear the front axle.
this is my daily driver and for now i do easy to moderate off roading, but i want to plan this right so it's the least amount of headache and most cost effective.
thanks for all input <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: d35 vs d44 #699082 02/21/06 06:15 PM
Mudlover27 Offline
WELL, ITS great that your planning ahead, so many times people don't do that and they pay more $ in the end.
Ok first things first, the Dana 35, and tires, I wouldn't even think of putting any money into it, I blew up the 35 with 31's on an open diff and I wasn't even wheeling!! Now if you put 33 on it, its just a matter of time, before its going to break!,
so here's a few options, 1 put the 33's on and leave the 35 and wheel the heck out of it till it breaks, then upgrade to a 44 or a 9 inch, put all your goodies in then (re-gear locker etc)
Don't bother beafing up the 35, its sort of a waste of cash (bigJim will chime in hear and give his 2 cents)
cheers
ML
Re: d35 vs d44 #699083 02/21/06 06:33 PM
BigJim Offline
You will be very unhappy with 33's and 3:07 gears.. I would wait till I had the money for a gear/axel change to put the tires on there.
I would use the front axel with new gears and it should be fine. While you are saving money you could spend some of it building a 44 rear with the gears you need. Then regear the front and install the rear and new tires all at the same time.. THAT would be my plan anyway.
Re: d35 vs d44 [Re: BigJim] #699084 02/22/06 08:10 PM
superdawg Offline
Why a xj 44? Not only are they very hard to find, but they are missing the link brackets you need?
Look for a tj 44, or disc brake 8.8 and get the re bracket kit.
Re: d35 vs d44 [Re: Mudlover27] #699085 02/23/06 01:43 AM
Reign Offline
im not trying to attack anyone one in any way that has blown a d35
BUT i have my d35 with 35in procomps and a detroit in it and it has been doing fine. some drivers just drive harder than others
but it would definatly be a good idea to change out the axles any ways if you have the money and no woman to chime in on the bills
94'YJ, I4, 4in sky jacker lift kit, 2in body, 35 12.50 pro comps, arb snorkle, detroit lockers
Re: d35 vs d44 [Re: Reign] #699086 02/23/06 02:48 AM
8.8 with 4.10 and 33's/4.56 and 35's my 02.
Re: d35 vs d44 #699087 02/23/06 04:52 AM
8.8, from an exploder, that way you get disc brakes. and parts are everywere
Re: d35 vs d44 #699088 02/23/06 06:50 PM
thanks everyone for your input. i have decided to look for a 44 cheap with the gears i want. does anyone have a good spot to look? (online store, good junkyard in the NY area) thanks again
Re: d35 vs d44 [Re: superdawg] #699089 02/24/06 02:35 PM
valleycat Offline
just got one for free last weekend.... with a lockrite. <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: d35 vs d44 [Re: valleycat] #699090 02/26/06 02:50 PM
superdawg Offline
Yippy skippy, Cat.
Invales, good luck.
SD
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6282 MB (Peak: 0.7348 MB) Data Comp: Off Server Time: 2026-10-21 17:31:13 UTC
