Mig welder???
#699486
02/22/06 02:38 PM
Good day guys...First time using a mig welder. Wire feeds but will not come through the end of the gun. Any help would be appreciated...Thanks! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Mig welder???
[Re: bigjeep1980]
#699487
02/22/06 03:25 PM
it maybe binding and not coming out, make sure the wire feed hose isnt kinked.The tip could also be fouled where the wire wont come out,remove the tip from the gun and pull the trigger to see if it comes out. those are the most common problems i ran into.if it isnt one of those let us know and we can go from there
Re: Mig welder???
[Re: cuervo25]
#699488
02/22/06 03:36 PM
Took tip off...seems fine, gonna unkink the wire the best I can...Big thanks for fast response <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Mig welder???
[Re: bigjeep1980]
#699489
02/22/06 05:01 PM
i usually have to put the wire in the tip manually and then screw the tip on.
94 yj 456gears, detroit locker and 30 spline axles out back, 33" bfgs
Re: Mig welder???
[Re: tomriddle]
#699490
02/22/06 05:38 PM
me too. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: Mig welder???
[Re: BigJim]
#699491
02/22/06 10:16 PM
i have to agree that manual unkinking of the hose is necessary prior to screwing in the tip
80 CJ-7. It runs
Re: Mig welder???
[Re: bigjeep1980]
#699492
02/23/06 02:29 AM
Jeep Moderator
Make sure the tip matches the wire. There's a little leeway, but obviously a fat wire won't feed through a small tip. Are you gas or flux core?
Re: Mig welder???
[Re: Berkeley]
#699493
02/23/06 01:51 PM
Thanks guys...Gonna go with the manual approach. It is a flux core. Chicago Electric Mig 100...I appreciate the help <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Mig welder???
[Re: bigjeep1980]
#699494
03/06/06 07:07 PM
I appreciate the help...I had to take apart the handle including the brass fitting,then removed the red feed tube snipping off the end where I could tell it was jammed. Put it back together and the sparks are now flying <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6237 MB (Peak: 0.7096 MB) Data Comp: Off Server Time: 2026-05-30 03:46:50 UTCValid HTML 5 and Valid CSS
