Stupid ??????? ATF fill 2nd Gen #699938 02/23/06 08:35 PM
Pilotbob Offline OP
OK Guys! I know, I know! Stupid question!
I've had this 2000 Trooper with automatic Tran, 3.5 V6 since it was new. I've never been able to find the transmission dipstick. I've been through the owners manual several times. Either I'm blind or it's not in there.
WHERE IS IT? Not the manual, the dipstick, Dipstick!
Bob
OK, so there isn't a dipstick! Just a filler hole with a plug in it?
Bob
Re: Stupid ??????? ATF fill 2nd Gen [Re: Pilotbob] #699939 02/23/06 09:23 PM
G
garyindiane Offline
Yep you got it.
Re: Stupid ??????? ATF fill 2nd Gen [Re: Pilotbob] #699940 02/23/06 09:24 PM
Socalboke Offline
Yep, that is one of those irritating Isuzu things, you almost have to have the trooper on a lift with it running, pull the upper plug which is about an inch or so higher than the drain plug and off to one side of the pan. it still faces down so if you have to add fluid you have to have a hose with a hook on it. I go to a trany shop near by and let them service mine once a year and then not worry about the mess, and these light duty A/Ts need extra care anyway.
Reid
Reid
96 Trooper, 94 Amigo, 89 swb RS trooper
Re: Stupid ??????? ATF fill 2nd Gen [Re: Socalboke] #699941 02/23/06 10:33 PM
txsoulfly Offline
Hey bob just do what I do. Go to homedepot and buy yourself a garder tank sprayer (with a pump to pressurize). The nozzle already has the perfect angle to snake it in. All you have to do is pressurize the tank and then squeeze the trigger. You might still spill a little, but it's better than using a suction pump with all its tubbing. HTH
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Mando
1998 Rodeo S 4x4 3.2, OME 913's, 2" coil spacers, Rancho 9000's
Re: Stupid ??????? ATF fill 2nd Gen [Re: txsoulfly] #699942 02/23/06 10:50 PM
Pilotbob Offline OP
So, doesn't it kind of P___ you off because we don't have a dipstick?
I've put 165,000 miles on my '91 and 58,000 miles on my 2000, and every time I have to check the oil in the auto trans, it P----- me off!
Maybe I'll drill a hole in the case and put a tube in it. Now I just need to borrow me a dipstick. I sure miss my dipstick!
Bob
Bob
'91 Trooper 3.4 V6 ARBs F&R, 33" BFG, 3.07 Teralows, 5.38 F&R, 4" lift, boulder bars, roof rack, torsion bars, Matt's tie-rod ends, manual hubs, heavy springs, homemade front and rear bumpers,rock sliderz, etc. 2000 Trooper
Re: Stupid ??????? ATF fill 2nd Gen [Re: Pilotbob] #699943 02/24/06 01:39 AM
holger Offline
If my memory does not fail me, the A/T dipstick was a special dealer-installed option on 2000+ Troopers, a part of the big "4x4 Dream Package". That package included selectable lockers on both axles, 4.77 ratios, 33" tires, a turbocharger, a snorkel and some others goodies (like tranny dipstick, top-mounted alternator, 32 gallons gas tank etc).
Oleg
Deceased Rodeo'02 4WD.
Re: Stupid ??????? ATF fill 2nd Gen [Re: holger] #699944 02/24/06 07:43 AM
maxwell417 Offline
.... a part of the big "4x4 Dream Package". That package included selectable lockers on both axles, 4.77 ratios, 33" tires, a turbocharger, a snorkel and some others goodies (like tranny dipstick, top-mounted alternator, 32 gallons gas tank etc).
Really? .... What a nice dream <img src="/forums/images/graemlins/cheers.gif" alt="" />
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Stupid ??????? ATF fill 2nd Gen [Re: Pilotbob] #699945 02/24/06 03:19 PM
HCMP Offline
I kind of like having my wrist watch smelling like tranny fluid.
Of course I like it better when I came back from Montreal and it smelled like dancers of the canadian "ballet". <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Stupid ??????? ATF fill 2nd Gen [Re: HCMP] #699946 02/24/06 09:25 PM
txsoulfly Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Mando
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6280 MB (Peak: 0.7326 MB) Data Comp: Off Server Time: 2026-06-07 09:10:06 UTC
