Centramatic balancers #699978 02/24/06 12:17 AM
jmsdad Offline OP
Got my set of centramatic balancers today. Fronts are mounted, but ran into a little problem with the rears. These drum balancing weights are in the way.
For those of you running centramatic balancers, did you grind them down? I'm thinking about doing just that, but want to check first.
Re: Centramatic balancers [Re: jmsdad] #699979 02/24/06 01:58 AM
4Crawler Offline
I had no problems with the rear drums on my '85. If grinding does not work, you might try a 1/4" wheel spacer to clear those projections.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5876 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-07-13 12:31:06 UTC
