Re: What type of oil do you recommend? [Re: DSHornet] #700068 03/02/06 05:46 AM
Calappoyas Offline
Doh! Fram is all I ever bought on any of my rigs for the past 20 years. Except for the air filter on the sportie which is OEM.
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
Re: What type of oil do you recommend? [Re: Calappoyas] #700069 03/02/06 05:59 AM
Mobil-1 20/50 and acdelco filter. change every 2k.
Re: What type of oil do you recommend? [Re: Calappoyas] #700070 03/10/06 03:45 AM
DSHornet Offline
This is a link to an old Web page, but it's still extremely interesting. A guy took apart several oil filters to look inside. After you read how the Fram filters are made, you might want to stop using them.
http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
Paw-paw Don, y'all
Favorite quote: "One need never apologize for exercising the Golden Rule."
Re: What type of oil do you recommend? [Re: DSHornet] #700071 03/10/06 12:44 PM
Axe Man Offline
Kia Moderator Emeritus
I saw that study years ago too. And yet I continued to use Fram filters and I never had any problems. Then I started lurking here...
http://bobistheoilguy.com/
They are also "down" on Fram products. In fact, I think the guy who did this original filter study also participates in this oil forum.
What persuaded me to stop using Fram filters was the fact that you can obtain Purolator filters cheaper and they are better quality.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: What type of oil do you recommend? [Re: Axe Man] #700072 03/11/06 08:56 AM
Billdo Offline
If you are really concerned about your oil, and the determination factor of when to change it, do an oil change, at the end of the 3000 miles send it HERE they will do 4 tests on your oil, including if your oil has started to breakdown. After using them for 1 year, I now only change my oil 4 times a year and use a K&N oil filter. The number one reason is because I use fully synthetic Mobil 1. Synthetic oil doesn't break down in the same manner as conventional oil. Unles of course you encounter a High heat situation. Such as an overheat. But either way, if you overheat your engine or even come close, you really should change your oil anyways. For example, I will change my oil on the first day of Winter, first day of Spring, Summer, and Fall. I started to notice that when I changed my oil only twice a year there was a very very small amount of water in it. Now that I change every season, there hasn't been any water in it at all.
Here is another thread that has been ongoing for awhile.
Good link as well.
Isuzu Thread article
2000 Chevy Tahoe nothing special. 1990 Isuzu Amigo, 3" lift, 31x10.5x15 BFG All Terrain (Street), 33x12.5x15 (offroad), Pacesetter header, some ATM rash. More mods to come......
Re: What type of oil do you recommend? [Re: Billdo] #700073 03/31/06 03:02 PM
wd8cdh Offline
Personally, I use anything but Fram filters. Either factory or Purolator most of the time.
For oil, I usually use Mobil 1 5W-30 or 0W-30 in the winter. Sometimes I use Shell Rotella synthetic if I can find it. Of the synthetics, Syntec is the worst one that is readily available. It's not a bad oil, just almost all synthetics are better.
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: What type of oil do you recommend? [Re: wd8cdh] #700074 03/31/06 03:41 PM
maraguez Offline
I go woth Mobil 1 15,000 mile oil. I have 170,000 or so miles on my truck. I change the oil every 15,000 miles. On a long trip (1,000 miles), it will use about 1 quart of oill since synthetic is thinner and escapes a little, but I have not openend my engine ever. It runs well and I just got tired of changing oils. I use the same oil in all my trucks.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
Re: What type of oil do you recommend? [Re: Calappoyas] #700075 03/31/06 11:10 PM
Nukeiridium Offline
Dang dude, now that you know fram sucks, your sportage is gonna explode...
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: What type of oil do you recommend? [Re: Nukeiridium] #700076 04/01/06 12:02 AM
Calappoyas Offline
Somehow I always knew I would die in car explosion... The kind you see in the movies <img src="/forums/images/graemlins/scared.gif" alt="" />
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6330 MB (Peak: 0.7538 MB) Data Comp: Off Server Time: 2026-11-02 14:20:30 UTC
