Clutch Pedal Problem
#700093
02/24/06 06:06 AM
I'm having a problem with my clutch pedal. I depress the clutch pedal and it just goes down but doesn't come up. I can't change into gear to drive it because there is no pressure with the pedal when depressing it. I see underneath that theres a leak and its definately coming from the brake fluid im putting in the clutch master cylinder because when i keep trying to depress the pedal the resovoir goes down. Anyone have any ideas on where the leak is coming from and is this a possible fix for an average do it yourselfer? Thanks in advance.
95.5 Rodeo, BONE STOCK 4x4,Mods Coming to a Zu near U.
Re: Clutch Pedal Problem
[Re: gr8ryde]
#700094
02/24/06 10:44 AM
Its your slave cylinder most likely, or a busted line.
[Re: garyindiane]
#700095
02/24/06 02:22 PM
Yep, sounds like the slave cylinder to me too.
#700096
02/25/06 02:01 AM
Pull the slave cylinder and pop the piston out. It's likely got some corrosion. I've been through 3 of them, and now bleed the system far more often. Any visible corrosion is enough to create a leak. You will need to replace the entire slave cylinder assembly, but that is easily within the ability of the do it yourselfer..
Don 1989 Trooper II 2.6L 222,222
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5957 MB (Peak: 0.6535 MB) Data Comp: Off Server Time: 2026-06-17 13:23:44 UTCValid HTML 5 and Valid CSS
