Clutch Pedal Problem #700093 02/24/06 06:06 AM
G
gr8ryde Offline OP
I'm having a problem with my clutch pedal. I depress the clutch pedal and it just goes down but doesn't come up. I can't change into gear to drive it because there is no pressure with the pedal when depressing it. I see underneath that theres a leak and its definately coming from the brake fluid im putting in the clutch master cylinder because when i keep trying to depress the pedal the resovoir goes down. Anyone have any ideas on where the leak is coming from and is this a possible fix for an average do it yourselfer? Thanks in advance.
95.5 Rodeo, BONE STOCK 4x4,Mods Coming to a Zu near U.
Re: Clutch Pedal Problem [Re: gr8ryde] #700094 02/24/06 10:44 AM
G
garyindiane Offline
Its your slave cylinder most likely, or a busted line.
Re: Clutch Pedal Problem [Re: garyindiane] #700095 02/24/06 02:22 PM
Yep, sounds like the slave cylinder to me too.
Re: Clutch Pedal Problem #700096 02/25/06 02:01 AM
Don_W Offline
Pull the slave cylinder and pop the piston out. It's likely got some corrosion. I've been through 3 of them, and now bleed the system far more often. Any visible corrosion is enough to create a leak. You will need to replace the entire slave cylinder assembly, but that is easily within the ability of the do it yourselfer..
Don
1989 Trooper II 2.6L
222,222
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5953 MB (Peak: 0.6531 MB) Data Comp: Off Server Time: 2026-06-07 07:22:28 UTC
