need help real bad with brake lights please !!! #700307 02/25/06 02:10 AM
leftnutt35 Offline OP
i can't get my brake lights to work changed all the bulbs changed the switch tested all the fuse's in the cad and under the hood took steering apart started testing wires in there blinkers work taillights work when the lights are on but breaklight want function any ideas ?? thanks
95 SR stock but i hope not for long....
Re: need help real bad with brake lights please !!! [Re: leftnutt35] #700308 02/25/06 02:14 AM
It's time to break out the wiring diagram and do some tracing...
1) download the mitsu factory manuals for the 89 montero (pretty much same as your model) from...
http://www.pajero.dn.ru/pdf/pajero-manual-pdf-big/
It will ask you for a login ID and password and if you look closely at the login screen you will see the ID & password.
Next time to break out the multimeter and do some troubleshooting.
Re: need help real bad with brake lights please !!! [Re: off-roader] #700309 02/25/06 03:00 AM
can't find what i need in there and its all french to me i gues its off to my mechanic.
Re: need help real bad with brake lights please !!! [Re: leftnutt35] #700310 02/25/06 03:04 AM
LRJ4x4 Offline
You get 5 posts then you have to post a picture of your truck...it's a rule <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: need help real bad with brake lights please !!! [Re: LRJ4x4] #700311 02/25/06 03:28 AM
V
v6lsmonty Offline
check the hazard switch. It seems to be the cause of most light problems. I had turn signal problems. after being totally stumped I just played around with the wires to the hazard, until they worked. I ended up leaving one of the wires disconnected. I think it was green and white but I can't remember exactly.
1989 Montero LS (sold)
1994 Cherokee Country bone stock
Re: need help real bad with brake lights please !!! [Re: v6lsmonty] #700312 02/25/06 05:11 AM
it was the hazard i figured out as i went out to play with it one last time before it got cold and where am i to post a pic of my rig at the gallery and is that really true seems kind of rude. javascript:void(0)
<img src="/forums/images/graemlins/nana.gif" alt="" />
Re: need help real bad with brake lights please !!! [Re: LRJ4x4] #700313 02/25/06 05:08 PM
V
v6lsmonty Offline
the above was a friendly request, I think. But if you think thats rude don't come to NY...you'll end up in tears. <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: need help real bad with brake lights please !!! [Re: v6lsmonty] #700314 02/26/06 03:13 AM
thats nice <img src="/forums/images/graemlins/baby.gif" alt="" /> i just got it all cleaned up it was really bad from sitting at a yard for a month or more. will take pictures soon.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6225 MB (Peak: 0.7013 MB) Data Comp: Off Server Time: 2026-06-13 10:46:07 UTC
