need help real bad with brake lights please !!!
#700307
02/25/06 02:10 AM
i can't get my brake lights to work changed all the bulbs changed the switch tested all the fuse's in the cad and under the hood took steering apart started testing wires in there blinkers work taillights work when the lights are on but breaklight want function any ideas ?? thanks
95 SR stock but i hope not for long....
Re: need help real bad with brake lights please !!!
[Re: leftnutt35]
#700308
02/25/06 02:14 AM
It's time to break out the wiring diagram and do some tracing... 1) download the mitsu factory manuals for the 89 montero (pretty much same as your model) from... http://www.pajero.dn.ru/pdf/pajero-manual-pdf-big/It will ask you for a login ID and password and if you look closely at the login screen you will see the ID & password. Next time to break out the multimeter and do some troubleshooting.
[Re: off-roader]
#700309
02/25/06 03:00 AM
can't find what i need in there and its all french to me i gues its off to my mechanic.
[Re: leftnutt35]
#700310
02/25/06 03:04 AM
You get 5 posts then you have to post a picture of your truck...it's a rule <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: LRJ4x4]
#700311
02/25/06 03:28 AM
check the hazard switch. It seems to be the cause of most light problems. I had turn signal problems. after being totally stumped I just played around with the wires to the hazard, until they worked. I ended up leaving one of the wires disconnected. I think it was green and white but I can't remember exactly.
1989 Montero LS (sold) 1994 Cherokee Country bone stock
[Re: v6lsmonty]
#700312
02/25/06 05:11 AM
it was the hazard i figured out as i went out to play with it one last time before it got cold and where am i to post a pic of my rig at the gallery and is that really true seems kind of rude. javascript:void(0) <img src="/forums/images/graemlins/nana.gif" alt="" />
[Re: LRJ4x4]
#700313
02/25/06 05:08 PM
You get 5 posts then you have to post a picture of your truck...it's a rule <img src="/forums/images/graemlins/smile.gif" alt="" /> the above was a friendly request, I think. But if you think thats rude don't come to NY...you'll end up in tears. <img src="/forums/images/graemlins/baby.gif" alt="" />
[Re: v6lsmonty]
#700314
02/26/06 03:13 AM
thats nice <img src="/forums/images/graemlins/baby.gif" alt="" /> i just got it all cleaned up it was really bad from sitting at a yard for a month or more. will take pictures soon.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6235 MB (Peak: 0.7022 MB) Data Comp: Off Server Time: 2026-06-10 04:27:53 UTCValid HTML 5 and Valid CSS
