95 Monty LS 4 Wheel Drive and AC #700403 02/25/06 08:47 PM
On a hot day above 95 degrees when I run my air conditioning my Montero will slip into all time four wheel drive. If I leave the air conditioning off this does not happen?
Anyone have any ideas.
Godon
Re: 95 Monty LS 4 Wheel Drive and AC #700404 02/25/06 09:12 PM
DougH Offline
Mitsubishi Forum Moderator
Have confirmed that it actually goes into 4wd, or is it just that the indicator lights flash?
Other than the indicator lights I can't think of any other way that the AC and 4x4 system could interact. The tcase is manually shifted so unless the shifter is popping into awd I am having a hard time of thinking of how this is happening.
DougH
1995 SR - RIP
1993 RS - RIP
Re: 95 Monty LS 4 Wheel Drive and AC [Re: DougH] #700405 02/26/06 05:17 AM
V
VA_95LS Offline
There is part of engaging 4wd, that uses vacuum.If you look at the front axel, you have a vacuum canister underneath with the vacuum actuator, on the axel, that locks the front hubs. It sort of like a Dodge Ram. So if you have a vacuum leak, those little indicator lights will come on saying there is not enough vacuum to move the actuator and engage 4wd. If you rev the engine and let off the vacuum is maximized and the indicator light should go off.
You probably have a vacuum leak, and when you turn on your ac, going down the road you put your foot into the accelerator more and you have less vacuum. You may have a little leak somewhere.
Salt gets on everything under there in winter here in VA, I'm always trying to get the salt off underneath, then spraying some wd 40 on the brake lines, and vacuum lines so the salt won't eat the lines and cause a leak. I hate salt on roads. I have 96k miles on my Montero, runs good but 11 years old. I don't know what I'll replace it with when that bad day arrives. They just don't build them like this anymore.
Thanks
Thanks !
1995 Montero LS (Owned since a pup)
1996 Dodge Ram 2500
1998 Jeep Wrangler 4.0
Re: 95 Monty LS 4 Wheel Drive and AC [Re: VA_95LS] #700406 02/26/06 06:07 AM
Thank you for the advice I will look for a vacum leak.
At 250,000 miles I have no idea what I'll do possibly rebuild and make it stronger when the day comes.
Gordon
Re: 95 Monty LS 4 Wheel Drive and AC [Re: VA_95LS] #700407 02/26/06 06:08 AM
Really appreciate everyone getting back to me on this.
Gordon
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5975 MB (Peak: 0.6623 MB) Data Comp: Off Server Time: 2026-05-29 16:13:57 UTC
