Any reason to not run w/o a sway bar? #700827 02/27/06 03:49 AM
BallaRat Offline OP
4Crawler and I were talking about this. I'll certainly take his word highly rated, though wanted to see others' thoughts. My '94 w/IFS was making a noise on the underside since November. Finally got it figured out, thanks to REALLY looking under the rig (d'oh!) The sway bar was completely broken right near the passenger side bracket. I really haven't noticed a lot of difference in the ride since November; this weekend I tore out the broken bar and brackets. Figuring on just running the rig without a sway bar at all. Any thoughts as to why that wouldn't be OK...?
Re: Any reason to not run w/o a sway bar? [Re: BallaRat] #700828 02/27/06 03:55 AM
jmsdad Offline
I tossed both from my 2 trucks(previous and curent). Slight body lean on twisty roads. Other than that, couldn't tell the difference!
If you feel like keeping it, you should be able to get a replacement pretty cheap and get some new bushings.
Re: Any reason to not run w/o a sway bar? [Re: BallaRat] #700829 02/27/06 04:01 AM
I removed the front swaybar on my 95 IFS when I replaced a CV. I don't miss it a bit.....
Re: Any reason to not run w/o a sway bar? [Re: BallaRat] #700830 02/27/06 04:01 AM
Rusty Davis Offline
I've run my last 2 vehicles w/out front or rear sway bars and there's nothing wrong with it.
As long as you are comfortable with the fact the body roll will increase and adjust your driving accordingly there is no harm in it. Some vehicles have more body roll than others after removing them.
For instance, my 98 Amigo had a lot more body roll after taking the sway bars off than my 94 4Runner. Friends said that my Amigo looked like it was going to tip over around corners whereas I hardly noticed the lack of sway bars in my Runner. Of course YMMV
Just to be on the safe side, be sure to warn anyone that may drive your vehicle that it has no sway bar(s)!
HTH, <img src="/forums/images/graemlins/cheers.gif" alt="" />
~R
94 4Runner 3.slow-5spd, 4" coils, 1.5" BJ spacers, 2" BL, 35x12.50 Nitto's, 5.29's with a front Lockrite and a rear Detroit; 250k miles and lots of offroad time...and by offroad I mean on jackstands.
Re: Any reason to not run w/o a sway bar? [Re: Rusty Davis] #700831 02/27/06 04:21 AM
BallaRat Offline OP
What? I let others drive my rig??? Perish the thought <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks for the replies. Like I said, I'm sure it's been broke since November on a Death Valley trip. I haven't really noticed any difference since, so I'll keep it all off. Yep, if I did put a new one on, it'd be with new bushings (grab the jam, the old ones are toast) and quick disconnects. But this is just one small step closer to a SAS, removing the parts the "natural" way.
Meanwhile...tires soon....very soon.
Don West
Gettin'Off4x4 Member
'94 Reg Cab, 1" BL, 33 MTs, Detroit f/r, 4.88s, dual Marlins, blah blah woof woof
Re: Any reason to not run w/o a sway bar? [Re: BallaRat] #700832 02/27/06 05:09 AM
Rusty Davis Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> I wouldn't let anyone else drive mine either, but you know...some people do <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: Any reason to not run w/o a sway bar? [Re: Rusty Davis] #700833 02/27/06 05:15 AM
willzrunna96 Offline
im nervous enough to bring my truck to toyota for the recall
Re: Any reason to not run w/o a sway bar? [Re: BallaRat] #700834 02/27/06 06:41 AM
I took mine off have had no problems
My 1st lift I put the extensions on only to snap
the heads off so made my own with some tubing and
all thread only to bend them all the time and noticed
that without I had alot more articulation so my 2nd
lift I threw it into the junk pile along with the
torque arm and ground off all the mounts 0n my axle
and Im a happy camper <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Any reason to not run w/o a sway bar? #700835 02/27/06 08:09 AM
I took the sway bar off of my old 88 Comanche straight axle, and that was the best thing I could have done. Now, I have a 96 T-100 with a LT front end, and no sway bar. I noticed a little more body roll, but nothing major. Once I revalved the shocks, the body roll got less as well. Removing it lets the front end actually be independent, but you get body roll. Just adjust your driving accordingly, and remember, it is a matter of personal preference. If you really wanted to, you could get a quick diconnect sway bar for your truck. My .02
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.013s) Memory: 0.6229 MB (Peak: 0.7270 MB) Data Comp: Off Server Time: 2026-11-17 11:24:58 UTC
