3.0 blowing white #701308 02/28/06 09:29 AM
cybak Offline OP
my 93 SR is blowing a little bit of white smoke (not alot but deffinetly coolant). there's NO over heating. i have one spark plug that looks a little oily, the rest are normal. i find no power loss. i just switched to synthetic oil a month ago (not sure if that means anything) i still have to do a compretion test and leakdown test. can anyone sugest anything or tell me what to look for thanks
93 Montero SR, 33x12.5's, 2" lift, 2.5" custom exhaust
Re: 3.0 blowing white [Re: cybak] #701309 02/28/06 01:15 PM
juggernaut Offline
Sound like you are on the right track.
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15
I caught this "JEEP thing" of your and now it hurts when I pee.
Re: 3.0 blowing white [Re: juggernaut] #701310 02/28/06 01:34 PM
Assuming the coolant leak is into the combustion chamber, the bad cylinder will have a very white plug, not oily. Run the truck to warm, let it sit for a couple of hours, and pull accessible plugs, then have someone crank it briefly while watching for water spit out of the plug holes (guard your eyes).
Re: 3.0 blowing white [Re: cybak] #701311 02/28/06 08:00 PM
LRJ4x4 Offline
Are you sure its coolant? The synthetic oil could be suspect?
Re: 3.0 blowing white [Re: LRJ4x4] #701312 02/28/06 08:30 PM
W
Winston Offline
Why?!?!
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: 3.0 blowing white [Re: Winston] #701313 02/28/06 09:37 PM
juggernaut Offline
Last variable that changed.
Might be thinnner than what you had, thicker may have been hiding issue.
Re: 3.0 blowing white [Re: juggernaut] #701314 02/28/06 10:12 PM
DarthRaider Offline
Auto trans? I am not sure if that trans uses a vacuum controlled modulator but that sounds like the symntoms of a leaking modulator. If it has vacuum line down to trans pull off end at trans and see if tranny fluid pures out. If it does replace modulator and top up trans fluid. Smoke will go away after you stop the supply (eventually) <img src="/forums/images/graemlins/cheers.gif" alt="" />
87 Dodge Raider w/mits 2.3 Turbo Diesel 5 speed
Re: 3.0 blowing white [Re: Winston] #701315 02/28/06 10:31 PM
LRJ4x4 Offline
Synthetic is very thin and slippery, It gets past worn valve seals. Don't put synthetic is a old motor <img src="/forums/images/graemlins/shame.gif" alt="" />
Re: 3.0 blowing white [Re: LRJ4x4] #701316 02/28/06 11:52 PM
W
Winston Offline
Viscosity is viscosity. It is true that Mobil 1 oils are on the thin side, but you can always just get something thicker like a 5W40.
I think it is a myth that synthetic oil causes seal leaks.
'95 Montero LS 160k
Re: 3.0 blowing white [Re: LRJ4x4] #701317 02/28/06 11:56 PM
There is no vacuum connection to the tranny.
If it's a coolant leak, the exhaust smell will be sweet. If it's atf, it smells like atf spilled on the hot exhaust manifold (ASL a fried a/t). Dunno what fried synth smells like. Coolant level drops? Any hard first of the morning cranking (hydrolock)? Any chocolate yoohoo in the oil pan? Any funny smells out of the radiator?
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6398 MB (Peak: 0.7471 MB) Data Comp: Off Server Time: 2026-11-03 17:44:57 UTC
