Pitman arm nut size........ #701330 02/28/06 03:24 PM
1
1FastSS Offline OP
I searched but could not find this. Anyone know the size of the nut that's holding the pitman arm to the steering gearbox? 30mm socket is the bigest I have.
Thanks.
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: Pitman arm nut size........ [Re: 1FastSS] #701331 02/28/06 04:18 PM
TexJeff87 Offline
I don't think it's that big...I wanna say 27...
If Mad Max had a 4runner...
Re: Pitman arm nut size........ [Re: TexJeff87] #701332 02/28/06 04:30 PM
Scerb Offline
I dunno if IFS and SA are the same size, but the IFS pitman arm nut is 32mm <img src="/forums/images/graemlins/kewl.gif" alt="" /> Expect to use a breaker bar/cheater pipe <img src="/forums/images/graemlins/shiner.gif" alt="" />
-Scerb
Re: Pitman arm nut size........ [Re: TexJeff87] #701333 02/28/06 04:31 PM
1
1FastSS Offline OP
My 30mm will not fit.....
Re: Pitman arm nut size........ [Re: 1FastSS] #701334 02/28/06 05:47 PM
TexJeff87 Offline
Well then don't listen to me... <img src="/forums/images/graemlins/smile.gif" alt="" />
Getting the nut off is the easy part, by the way. You are in for a real wrasslin' match with the arm...
Re: Pitman arm nut size........ [Re: 1FastSS] #701335 02/28/06 09:07 PM
4WD22R Offline
Thanks.
Yup, it's a 32mm, I picked up a crapsman one for about $6. Jeff is right tho, gettin the arm off of the splines is a real pain. Get yourself a decent pittman arm puller i.e. NOT harbor freight, I broke one of those in half and the half that came off almost took my head out <img src="/forums/images/graemlins/scared.gif" alt="" /> I got one from auto bone and it worked for me. Soak the splines in PB blaster or your favorite brand of penetrating oil a couple of days in advance, then use a good long beaker bar, mine's a 18 incher and it came off super easy, well, once I got the right puller that is <img src="/forums/images/graemlins/lol.gif" alt="" />
Good Luck!
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Pitman arm nut size........ [Re: TexJeff87] #701336 03/01/06 05:31 PM
V
Volcom Offline
My buddy just had to cut his arm off of the box. He soaked it for weeks, used some heat, beat on it, used every puller he could get his hands on and still wouldn't come off. Good luck!
Re: Pitman arm nut size........ [Re: Volcom] #701337 03/01/06 07:42 PM
ACES_HI Offline
+1....Get an angle grinder and cut it off. Just dont cut into the splines. You'll be doing yourself a huge favor cause them suckers are practically welded on there, puller or not. <img src="/forums/images/graemlins/zombie.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Pitman arm nut size........ [Re: ACES_HI] #701338 03/01/06 07:45 PM
4Crawler Offline
I usually find applying the puller and leaving it on and tight for a while helps. Periodically snug it up and also levering down on the end of the pitman arm, while the puller is on helps, too. And be sure to apply some anti-sieze on the splines before installing the arm.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6270 MB (Peak: 0.7310 MB) Data Comp: Off Server Time: 2026-07-14 11:13:06 UTC
