pump, injector service in NC and brake question #701572 03/01/06 03:24 AM
TommyC Offline OP
I am having so much fun tearing this thing apart. Anyhow, there are a few things that are beyond me. One of which is servicing the pump and injectors. I've read on this forum about using Diesel Equipment Service in Greensboro. I'm planning on taking both parts there, but will I need to give them the specs? I have a manual, but if I'm planning on running B100, is there anything that they can do to bump up the pressure and make it push through the thicker stuff?
Also, I have a donor vehicle (dec 87) with 4 wheel disc brakes. Is it worth the effort to change master cylinders? Is the bias the same with my old one?
Also, if anyone wants to pick on my 87 carcass around Durham way, you're welcome to.
Thanks!!
Tom
Re: pump, injector service in NC and brake question [Re: TommyC] #701573 03/01/06 05:06 PM
turboDIESELtrooper Offline
Tom, is the donor 87 Trooper a diesel? If so I may need some parts. Thanks.
Salvy
Re: pump, injector service in NC and brake question [Re: turboDIESELtrooper] #701574 03/01/06 07:15 PM
TommyC Offline OP
I wish. It was a gasser, but the engine is long gone.
Re: pump, injector service in NC and brake question [Re: TommyC] #701575 03/02/06 03:37 AM
DES is an Akai authorized service center (or were when I was last there). They can do anything to the fuel injection system and have everyhting. Just carry it all down there and install it when they are done. They have done great work for me.
I make my own biodiesel and run B100 and have no problem with fuel delivery and don't beleive a pressure build is in this system's best interest anyway. They could advise yu better of course, and I would listen to every word they say.
Good luck,
NCDiesel
Re: pump, injector service in NC and brake question [Re: TommyC] #701576 03/07/06 12:51 AM
crossbones Offline
Hello Tommy.I may have need of the trooper body. If all you need is the injectors cleaned and the pop off pressure set I can do that for you as well as set the IP timing. I am in Durham.
crossbones
1982 Luv Diesel 4X2
1982 Luv Diesel 4X4
1981 Luv diesel 4X2
1983 Isuzu Diesel 4X4
1986 Trooper TD
Re: pump, injector service in NC and brake question [Re: crossbones] #701577 03/07/06 03:19 PM
kravdraa Offline
Would increasing the pressure be something that is necessay for Bio-Diesle use? (not trying to be a flamer here, just asking)
My understanding is that at the proper temperatures (using B-100 above about 45F) it is about the same viscosity as #2 Diesel. (well I guess it is a bit thincker)..but wouldn't increasing the pressure influence the fuel mileage?
Just bouncing a couple of questions around.
Eric
VA
Re: pump, injector service in NC and brake question [Re: crossbones] #701578 03/08/06 05:01 AM
JLEMOND Offline
HEY JAMES I HAVE AN 86 TROOPER BODY AND AN 87 THAT WILL BE AVAILABLE , A FEW PIECES MISSING, BUT NOTHING MAJOR, OTHER THAN ENGS AND TRANNYS, NO TIRES OR WHEELS ON THE 87 GOOD GLASS 4DOOR, GOOD METAL ALL AROUND, NO GRILL OR HEADLITES , 86 BODY AND FRAME, I NEED TO KEEP SOME OF THE FRONT END PARTS BUT IT HAS A 1 YEAR OLD 4.56 LSD REAR END IN IT ,NO SEATS OR BUMPERS, SPENCER GOT THEM, SOME GLASS MISSING AND THE BIG DOOR IS DENTED BUT STILL CLOSES TIRES AND WHEELS STILL THERE, AND FRT SUSP STILL USABLE VERY VERY CHEEP NEED TO MOVE EM OUT JERRY
Re: pump, injector service in NC and brake question [Re: JLEMOND] #701579 03/09/06 02:07 AM
Jerry, is the one year old 4.56 LSD rear out of another Isuzu 4WD vehicle or did it come out of an older Trooper? Didn't just about every 86 Trooper come without an LSD rear end from the factory? I have an 86 Trooper 4 door and would like to ask if you'd be interested in selling just the rear end out of your 86? Will an LSD rear be better for off-roading than a normal non-LSD rear? Thanks for your reply.
Salvy
Re: pump, injector service in NC and brake question [Re: turboDIESELtrooper] #701580 03/09/06 02:58 AM
JLEMOND Offline
HI SALVY , THAT IS CORRECT THE 86 WERE NOT AVAIL;ABLE I THIS COUNTRY WITH AN LSD , HOWEVER ALL YOU HAD TO DO WAS USE THE LSD FROM AN EARLY MODEL IMPULSE THAT CAME WITH THE TURBO END AS IT HAD THE SAME REAR END, , THIS PARTICULAR ONE I SOLD TO A GENT JUSTA BOUT A YEAR AGO AND HE INSTALLED IT IN HIS TRUCK AND ABOUT 2 MO, BACK THE ENG BROKE AND I ENDED UP WITH THE WHOLE TRUCK, SO YES IT IS AVAILABLE I DON,T KNOW ABOUT THE SHIPPING THAT FAR I AM NORTH OF ATLANTA,ABOUT 60 MI, IT IS NOT ALL THAT HEAVY MAYBE 150 LBS BUT IT IS ACKWARD TO SHIP, MY WIFE IS HEADING FOR PITTSBURG NEXT MONTH BUT SHE MIGHT GET MADE AT ME IF STUCK IN THE BACK SEAT OF HER HONDA AN YES IT IS FOR SALE , JUSTA FEW MORE PARTS TO BE REMOVED AND IT IS GOING TO THE CRUSHER, 150.00 FOR THE COMPLETE REAR WITH THE BRAKE DRUMS AND CABLES , JERRY
Re: pump, injector service in NC and brake question [Re: kravdraa] #701581 03/09/06 04:54 PM
TommyC Offline OP
Hey,
I think I might've combined two thoughts into one. There are a few companies that are coming out with single tank systems for running SVO (like elsbett), and they seem to have a common thread... they change the nozzles and boost the pressure to accomodate the thicker veggie oil. I don't think I'd have to do much to actually run b100, just planning ahead. Sorry for the confusion.
TC
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6368 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-06-23 03:12:58 UTC
