Page 1 of 4 1 2 3 4
tundra axle width #701792 03/01/06 06:04 PM
mrvoodoodaddy69 Offline OP
anyone know the width of the tundra axle?
also am i correct in thinking that if it was close to
a t100 width you could get a trd tundra axle and add
the toyota e-locker to it? or am i out in left field
somewhere.
Re: tundra axle width [Re: mrvoodoodaddy69] #701793 03/01/06 08:41 PM
Jake97T Offline
The tundra rear axle is the same, pre e-locker rear end...the e-locker can be put into the T100 axle housing with a little bit of modification, you would have to do some notching on the e-locker side of the axle housing and a bit of welding, its been done on the mini toyotas but havent seen anynone with a t100...
Re: tundra axle width [Re: mrvoodoodaddy69] #701794 03/01/06 08:48 PM
surlynkid Offline
YOU CANNOT STUFF AN ELOCKER IN THE T-100 AXLE!!!!!!!
you can put it in a mini 8" axle housing with modification, but not in a T-100. The tundra rear axle is the same as a T-100. the TRD tundra does not get an elocker like a trd taco does.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: tundra axle width [Re: surlynkid] #701795 03/01/06 09:04 PM
Jake97T Offline
i was under the impression the tundra had an e-locker option in the TRD..., but if it did im sure they went with a very different housing... <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />, i guess if not an ARB would be in order.
Re: tundra axle width [Re: Jake97T] #701796 03/01/06 09:13 PM
i was afraid that this little idea was too good to be true.
oh well back to savin pennys for the arb
Re: tundra axle width [Re: mrvoodoodaddy69] #701797 03/01/06 09:16 PM
Jake97T Offline
ive talked to a few people about the lock-rite locker, but my guess is that it's not very strong...what other drop in locker s would be a better alternative to a spool, which i wouldnt mind if i only drove in the dirt...
Re: tundra axle width [Re: Jake97T] #701798 03/01/06 09:35 PM
4
4xGeek Offline
The Loc-Rite is plenty strong... Plenty noisy, but strong. A quieter alternative is the PowerTrax No-Slip...
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: tundra axle width [Re: Jake97T] #701799 03/01/06 09:56 PM
surlynkid Offline
i used a lock rite for a while. just some clickity clicks and an occassional BOOM. be careful on wet pavement. don't be stupid and a lock rite can last.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: tundra axle width [Re: Jake97T] #701800 03/01/06 09:57 PM
surlynkid Offline
nope, no locker. ARB or lock rite.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: tundra axle width [Re: surlynkid] #701801 03/01/06 10:39 PM
Jake97T Offline
when does the lockrite go boom, and describe wet pavement behavior. <img src="/forums/images/graemlins/baby.gif" alt="" />
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6381 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-06-17 16:39:16 UTC
