backspacing #702089 03/02/06 07:39 PM
Billdo Offline OP
I have done some research and just don't quite understand how the whole backspacing thing works. I recently was approached with a really good deal on some Mickey Thompson Classic wheels that have the 6 x 5.5 bolt pattern but it has 3 5/16 backspacing, now my question is, would that make the tires stick out too far on a first generation Amigo.
2000 Chevy Tahoe nothing special. 1990 Isuzu Amigo, 3" lift, 31x10.5x15 BFG All Terrain (Street), 33x12.5x15 (offroad), Pacesetter header, some ATM rash. More mods to come......
Re: backspacing [Re: Billdo] #702090 03/02/06 08:02 PM
bob large Offline
should be cool. the first gen amigos didn't have nearly as much backspacing as other isuzu's. but don't plan on too big of a tire.
Steve C
Re: backspacing [Re: bob large] #702091 03/02/06 09:13 PM
barak Offline
I believe the average back spacing is 3 to almost 4 , depending on the type of truck , so those rims you were looking at should be ok.
Re: backspacing [Re: Billdo] #702092 03/02/06 11:51 PM
mlclark Offline
Isuzu Moderator
How wide are the wheels? That will make a difference. 3 5/16" on a 8" rim will be much difference in overall vehicle width than a 10 or 12 inch rim.
Michael
Re: backspacing [Re: mlclark] #702093 03/09/06 07:04 AM
Billdo Offline OP
They are 15x8
Re: backspacing [Re: Billdo] #702094 03/09/06 07:10 AM
mlclark Offline
Isuzu Moderator
Then, the center of the wheel will be almost centered in the rim. The shell will be pushed out 11/16 of an inch.
They should be close to stock and they should work for you. But, I would measure one of your current wheels for BS and rim width and see how they compare. I don't want to tell they will be OK without you checking to make sure. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
Re: backspacing [Re: mlclark] #702095 03/09/06 08:26 AM
Billdo Offline OP
Thanks for all of your input.
I now understand.
Bill
Re: backspacing [Re: Billdo] #702096 03/14/06 09:52 PM
rheteric Offline
This begs the question....
Are there any stores out there that will guarantee wheel fitment? I am in the market to get some wheels, and it is my worst nightmare that I have to special order some 5 on 6.5 x.x" backspaced rims, they don't work out for me, and I am stuck with 4 shiny new $200 bar stool bases <img src="/forums/images/graemlins/scared.gif" alt="" />. Do most places reorder and remount until something fits? Because it is my experience that these 2nd gen Rodeos have some pretty unforgiving dimensions and if I deviate only slightly from stock I am going to have clearance issues. Am I overthinking this???
www.burnlounge.com/mp3me
'00 Rodeo LS 4x4; "K&N" cone filter; S/S Manik Front, Rear, & Nerf; 'Modest' sound system; 1.5" R'ooper lift, 265/70/16 Dunlop RVxt, Skyjacker Hydros, OEM LSD (sans G80 code)
Re: backspacing [Re: Billdo] #702097 03/14/06 10:12 PM
strawmyers Offline
Isuzu Moderator
I have those same wheels on the same vehicle you're asking about. They stick out about 1.25" more on each side versus the OEM snowflakes. IMHO, its just right... gives a little extra stance for stability but not ridiculous to where 1/2 the tread is outside of the fenders. Here are some pics:
With OEM snowflakes:
MT Classic II's:
BTW, as a word of advice, the center caps on these wheels rust like no other. I have had mine for just over a year and two of the center caps were about 50% rust (the weather around here probably has a lot to do with that). This Saturday, I pulled all 4 wheels, cleaned the center caps up as much as I could and hit them with a few heavy coats of clear wheel paint. I'd recommend doing that before you install them.
Sean Strawmyer
Re: backspacing [Re: rheteric] #702098 03/14/06 10:47 PM
CPOM Offline
I highly doubt it because of the labor involved in mounting etc. Can you get involved with a club that someone will let you borrow their wheels to check how they fit then adjust from there. Many GM and toyota use this pattern.
I used graph paper when figuring out what wheels to pick last time I did to measure how much more the tires will stick out due to change in wheel and tire width.
CHRIS
98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6332 MB (Peak: 0.7425 MB) Data Comp: Off Server Time: 2026-10-24 04:10:38 UTC
