16" Snowflake Wheels on 94 Trooper #702134 03/02/06 11:16 PM
reran Offline OP
Anyone know what the offset is on these wheels compared to the stock offset on the Trooper wheels? I found a set and am considering installing w/265/75x16 tires, they're 16x7.5. Will they fit w/o sticking out too much? Any tire rub? All opinions appreciated. Thx.
94 Trooper S, 3.2 SOHC, Auto, Aisin's, OME 912's, TBC, Indy 4x HD TRE, Tokico shocks, AR Outlaw II's 16x8, Bridgestone Revo's 265/75x16
89 Trooper S, 2.6, auto, work in progress
Re: 16" Snowflake Wheels on 94 Trooper [Re: reran] #702135 03/03/06 04:09 PM
Smiley Offline
Tad (Nazrat) has a 1994 Trooper with 15ö Snowflakes on it.
Shoot him a PM û heÆll probably know for sure.
[EDIT]
Oops... I just re-read the title.
As far as I know, most 16" Snowflakes were Zero offset.
The ones on Joe's (BigPoppax2) Passport are - They came off of Rodeo_Chris' 1994 Rodeo.
[/EDIT]
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: 16" Snowflake Wheels on 94 Trooper [Re: Smiley] #702136 03/03/06 04:37 PM
Bigpoppax2 Offline
The difference in the 38mm offset that is stock on second gens and the 16x7.5 snowflakes that are 0 offset is 1-1/2" wider track per wheel So a total of three inches wider track for your truck. But it all depends on what you have on there currently.
I'm sure it will be fine. Tad was running wheel spacers to make his track wider with the snowflakes on his.
Joe
Re: 16" Snowflake Wheels on 94 Trooper [Re: Bigpoppax2] #702137 03/03/06 04:55 PM
ducktrooper Offline
Just curious..would these snowflakes work well with 285/75/16's, as I am considering getting some also for my 99 Trooper?
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Re: 16" Snowflake Wheels on 94 Trooper [Re: Bigpoppax2] #702138 03/03/06 07:37 PM
holger Offline
The difference in the -38mm offset that is stock on second gens and the 16x7.5 snowflakes that are 0 ...
my understanding is that the stock offset is +38mm, not -38mm.
Oleg
Deceased Rodeo'02 4WD.
Re: 16" Snowflake Wheels on 94 Trooper [Re: holger] #702139 03/03/06 08:57 PM
Bigpoppax2 Offline
I believe you are correct.
Re: 16" Snowflake Wheels on 94 Trooper [Re: reran] #702140 03/04/06 03:40 AM
reran Offline OP
Ok guys, if I processed all this info correctly, then as Joe says, I'll have a 1.5" wider track... and the wheels will stick out 1.75" more than stock. So how will this effect tire clearance? Will I still be ok with 265/75x16 tires w/o a lift? If I need to lift it, then I'll probably put the money toward something that will give me more bang <img src="/forums/images/graemlins/wink.gif" alt="" /> for the money. What about Teralow's or a locker? Whatta y'all think?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6186 MB (Peak: 0.7090 MB) Data Comp: Off Server Time: 2026-05-29 23:37:50 UTC
