Oil pressure gauge - dead #702248 03/03/06 03:04 AM
8
88Suzy Offline OP
I have an '88 trooper with 2.6L. When I bought the truck, the oil pressure gauge worked fine. After removing the cylinder head for replacement, the oil pressure gauge is now dead -- 0. I know I have oil pressure. Also the dummy light goes off when the engine starts. Anybody know what I might have affected by only removing the engine top end?
Re: Oil pressure gauge - dead [Re: 88Suzy] #702249 03/03/06 03:36 AM
Have you checked all the wiring to the gauge from the oil pressure sensor?If it got tangled in something when you pulled the head you could of pulled the wire or possible have broken it.
If all thats good you can check the gauge by hooking the wire going to the gauge to an electrical ground and then blipping the key to see if the gauge moves. If the gauge maxes out while the key is turned your sensor is bad. And if it doesn't move then you gauge is bad.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5848 MB (Peak: 0.6340 MB) Data Comp: Off Server Time: 2026-11-15 19:37:48 UTC
