Rough EVERYTHING (Now w/ backfire) #702504 03/04/06 02:00 AM
kuso Offline OP
Okay, after replacing my fan pulley bracket and changin' out my valve cover gaskets, I now have another problem to deal w/. My truck has a rough idle and take off accompanied w/ a new feature never seen (at least to me on a Toyota): Backfire!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
I checked all of my vac. lines in accordance w/ the FSM and all seems to check out. I checked all the electrical connections before I put the intake chamber back on and all seemed well there too. What are some areas I can recheck this weekend so's I can get my rig up and running again?? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> I'll undoubtably be pulling that f'n AIC back off again this weekend...fun fun! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
My poor truck sounds like a tractor now! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Thanks!
-kuso <img src="/forums/images/graemlins/shiner.gif" alt="" />
'91 Toyota, X-cab, 3.0, SR5, 4x4, Automatic Leech Tranny, 31" Generics, "KaTooM Carrier" 201K and runnin' smooth!
Many a good man has failed because he had his wishbone where his backbone should have been.
--Unknown
Re: Rough EVERYTHING (Now w/ backfire) [Re: kuso] #702505 03/04/06 02:42 AM
CORunner93 Offline
Did you take the spark plug wires off? Sounds like the firing order is messed up....as in wonrg wire to the wrong plug.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: Rough EVERYTHING (Now w/ backfire) [Re: kuso] #702506 03/04/06 03:30 AM
4Crawler Offline
Could also be an air/vacuum leak somewhere on the intake or air hose from the filter. You can run something like propane around the seams and see if you can find out if the engine smooths out. Mine will backfire if I have a leak at the air intake hose between the AFM and throttle body.
Re: Rough EVERYTHING (Now w/ backfire) [Re: CORunner93] #702507 03/05/06 05:05 AM
kuso Offline OP
You nailed it! <img src="/forums/images/graemlins/kewl.gif" alt="" /> I had the 1-3-5 firing order all screwed up! Not good. Kinda figured it was something simple that I overlooked, but shame on me for wasting up forum space (kinda like right now w/ this reply <img src="/forums/images/graemlins/drunk.gif" alt="" />)!
Thanks for the responses 4Crawler and Corunner <img src="/forums/images/graemlins/patriot.gif" alt="" />
--Unknown
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6069 MB (Peak: 0.6634 MB) Data Comp: Off Server Time: 2026-06-07 03:14:00 UTC
