22RE alternator install - remove lower radiator hose? #702726 03/05/06 01:03 AM
P
PoBoy Offline OP
Tried searching and got 40,000 alternator questions. So here is 40,001:
Is there a way to get the alternator out without removing the lower radiator hose? If not, any trick to removing the hose w/o doing a drain or keep the mess minimal? If I have to drain - how much fluid are we talking about?
I have power steering, so no room to go out the top.
1985 4Runner w/ 22RE EFI
Re: 22RE alternator install - remove lower radiator hose? [Re: PoBoy] #702727 03/05/06 01:09 AM
4Crawler Offline
You can probably do it w/o removing the hose, but it is so much easier with the ose off. 2 gallons of coolant, use a bucket and you can refill when done. I did this swap on the side of the road once, 5 minutes to drain the rad and the same to refill.
Re: 22RE alternator install - remove lower radiator hose? [Re: PoBoy] #702728 03/05/06 01:10 AM
4WD22R Offline
I've got pretty much the same setup cept for a year newer and a carb.....but I pushed pulled and yanked on it for about 30 mins and I managed to squeeze it out the top.....I didn't want to drain my radiator <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: 22RE alternator install - remove lower radiator hose? [Re: PoBoy] #702729 03/05/06 01:11 AM
TimsToyo Offline
I've got an '86 22R but the configuration should be the same. It can be done without taking off the hose. You just have to keep turning it until you get it out topside.
'86 Toyo 4wd
'04 600RR
Re: 22RE alternator install - remove lower radiator hose? [Re: TimsToyo] #702730 03/05/06 02:02 AM
cmrg63 Offline
I have a 91 pickup with a 22RE I changed my alternator yesterday the powersteering hose is in the way to take it out the top. Remove the lower hose it much quicker.
Re: 22RE alternator install - remove lower radiator hose? [Re: cmrg63] #702731 03/05/06 02:12 AM
4WD22R Offline
nope, she'll come out, ya just gotta have the touch and be reeeel gentle like <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: 22RE alternator install - remove lower radiator hose? [Re: PoBoy] #702732 03/05/06 02:27 AM
87Toy4x4 Offline
you have 37k on your truck and need a new alternator? mine is original w/ 151k on it.
Re: 22RE alternator install - remove lower radiator hose? [Re: 4WD22R] #702733 03/05/06 02:50 AM
TimsToyo Offline
At first glance you wouldn't think that it can come out the top but it can. <img src="/forums/images/graemlins/cheers.gif" alt="" />
'86 Toyo 4wd
'04 600RR
Re: 22RE alternator install - remove lower radiator hose? [Re: 4WD22R] #702734 03/05/06 03:30 AM
stock87 Offline
+1
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: 22RE alternator install - remove lower radiator hose? [Re: 4Crawler] #702735 03/05/06 06:56 AM
P
PoBoy Offline OP
Just 2 gallons aye? I'll pop it off then and refill with fresh. I was thinking a lot more and a big mess resulting.
Thanks!
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6414 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-06-17 12:00:26 UTC
