Page 1 of 3 1 2 3
Spark Plugs #702912 03/05/06 03:20 PM
ttus Offline OP
am getting Mixed info, on the gap for a 04 Tacoma 2RZ 4 cyl.
I took out 4 NGK ( BKR5EYA ) plugs, they were gapped at .54. I thought that is a very big gap.
I went to the dealer, and brought 4 Toyota plugs ( K16R-U11 ) and had one of the mechs look up the correct gap. He said it
should be .31. The dealer where I got the plugs said they are "Pregapped". The gap on them was .43.
I looked at some more info, and it said, that they should be .43. on my 2RZ 4 cyl. also.
Something isn't right somewhere.
I regapped the new plugs to .31 and installed them. I didn't read all of the above till after I
had set them to .31 and installed them.
And if you have done this, it takes awhile to get all of the air system out of the way and then to put it back.
So, now I am in a Total wonder on what the correct gap should be. <img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks for any help.
Re: Spark Plugs [Re: ttus] #702913 03/05/06 10:09 PM
Mark in AZ Offline
Toyota Moderator
From the online factory manual posted at the top of this forum:
http://misc.mmdsi.net/tacoma/tacoma-manual/Repair_Manual/03tacoma/ig2rzfe3/ignsy/ovi.pdf
Second page, about 1/2 way down.
The gap is listed in your owner's manual...I would use that gap before the 2003 FSM linked above. Just as cross check, do you have the plugs that were taken out, for a reference?
A bit nitpicky, but those measurements in inches are .031, .043, and .054
Exploring in a T4R Ltd V8
Re: Spark Plugs [Re: Mark in AZ] #702914 03/06/06 12:25 AM
ttus Offline OP
Mark in AZ Thanks for your reply.
Yes, I have the plugs that were in it. As, I said they were NGK BKR5EYA and the gap was .54. That is what got me checking. I thought "Boy that sure is wide". And after looking and calling the dealer, I was correct. .31 verus .54, "Unreal" <img src="/forums/images/graemlins/scared.gif" alt="" />
I gapped the new plugs at .31, Toyota # K16R-U11. As I said on the onset. Dealer said that they were "Pregapped", they were gapped at .43 Not .31. Had to regap them.
Thanks
Re: Spark Plugs [Re: ttus] #702915 03/06/06 01:59 AM
hupptoy Offline
Thanks
What does your owner's manual say the gap should be?? How many miles on on your truck and what is the plug change interval recomended in the manual?
And (yes, nitpicky...) if you are measuring in inches, I hope you mean .043" and not.43" etc. Just want to make sure you are relaying correct info.
I know when I changed plugs on my 3.4 at 60K, I found that the dealer *forgot* to change them at 30K (don't use that dealer anymore). Anyways, my gaps were huge (2-3 times specs) but that was mostly due to extreme wear from the double service life...
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: Spark Plugs [Re: hupptoy] #702916 03/06/06 02:07 AM
ttus Offline OP
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Yes it is .043 and .031 in my post.
Boy a gap at .43 and etc, would be a real deal. LOL
It is a 04 2RZ-FE with 27,000 on it. It says change every 30K in the book. It gives NO gap info.
Thanks
Re: Spark Plugs [Re: ttus] #702917 03/06/06 03:25 AM
I just checked my manual for my 04 3.4 and I couldn't find any gap info either...
Weird! <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Spark Plugs #702918 03/06/06 04:09 PM
For the 3.4 2001 engine my factory manual calls for .043 or 1.1mm gap on the plugs.
Re: Spark Plugs [Re: ttus] #702919 03/06/06 05:50 PM
hupptoy Offline
My 99 4Runner Owner's Manual (not the Maintenance schedule) lists the plug gaps in the SPECIFICATIONS section under ENGINE.
Since the 99 4Runner did not come with the 2RZ (2.4), I can not help you on gap, but the 3RZ (2.7) is listed at .031 and the 5VZ (3.4) is .043.
NGK and Denso lists .044 for all 3 engines for the 2004 Tacoma.
Hope this helps.
hupptoy
Re: Spark Plugs [Re: hupptoy] #702920 03/07/06 05:36 AM
Oops, there it is on page 323... <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Spark Plugs #702921 03/07/06 06:00 PM
Mark in AZ Offline
Toyota Moderator
Geez, there's the problem, we forgot to give the page number <img src="/forums/images/graemlins/drunk.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/pfft.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.011s) Memory: 0.6368 MB (Peak: 0.7595 MB) Data Comp: Off Server Time: 2026-10-21 22:05:07 UTC
