Page 2 of 3 1 2 3
Re: Power Inverters: Who's all got them? [Re: Angelo] #703428 03/07/06 04:47 PM
I've got two power inverters. One is a small unit which I use for a laptop or to power my christmas lights this past winter.
The other is a bigger unit 1.75"x12"x8" which sits in back mounted to the side of my tool box, is hardwired to the battery (fuse removed) and rarely gets used.
Re: Power Inverters: Who's all got them? [Re: off-roader] #703429 03/07/06 06:47 PM
Fancy87Raider Offline
[img][image]http://img346.imageshack.us/img346/5276/10008910kp.jpg[/img][/image]
This is the power connection that runs into a relay that is on the ignition panel for on and off of main power. (Sorta like Frank's)
[img][image]http://img443.imageshack.us/img443/6120/10008900ne.jpg[/img][/image]
This red switch is the switched power for the unit. So the unit has a heavy power supply when the truck is on althought you can turn the unit on and off with this switch.
Over view of the dash. As you can see this looks factory. <img src="/forums/images/graemlins/kewl.gif" alt="" />
87 Raider-31x10.5 Trexus M/T,5" Shackels,T-Bars jacked up,home made CHOP-TOP
Re: Power Inverters: Who's all got them? [Re: Fancy87Raider] #703430 03/07/06 06:55 PM
Ohh forgot I sell coleman and vector units (my name brands) and some off brand stuff like pyle and boss. I would like to carry honeywell but there is not much demand for such high powered units.
Re: Power Inverters: Who's all got them? [Re: Fancy87Raider] #703431 03/07/06 08:09 PM
If you plan to run electronics or smart battery chargers, get a unit that puts out as close to a true sine wave power as possible. Most cheaper inverters put out a square wave, which makes some power supplies very unhappy. My el cheapo radio shack 300w won't run my charger for the Dewalt 18v tools because the square wave freaks out the brain inside the charger. I've heard of the same problem with some laptops.
Re: Power Inverters: Who's all got them? [Re: fasteddy] #703432 03/08/06 02:49 AM
OKRED Offline
My yota has one built into the bedwall. Used it twice: sanding bottom paint off the boat and an angle grinder at the junkyard.
A brand spankin new 1973 series 3 Landy
OLIVE DRAB SWB, TURBO, IN ABOUT 36 PIECES
89 TROOPER, RESCUED FROM THE YARDS. (Down again)
05 TACOMA CREW SHORTY.
Re: Power Inverters: Who's all got them? [Re: fasteddy] #703433 03/08/06 04:22 AM
FrankR Offline
Most of the newer small units now use a modified sine wave - not quite a true sinusoidal oscilliscope pattern, but not as blocky as the square wave - more of a clipped, flat-top sine wave. I haven't tried mine on a laptop yet, but it runs an electric drill, fridge, compressor, battery charger, etc. just fine.
Frank
Re: Power Inverters: Who's all got them? [Re: Fancy87Raider] #703434 03/08/06 04:23 AM
FrankR Offline
The dash outlet and switch does look factory... nice job!
Frank
Re: Power Inverters: Who's all got them? [Re: FrankR] #703435 03/08/06 04:32 AM
thank you, i put it in tto run my laptop and it works great. it is a coleman unit.
Re: Power Inverters: Who's all got them? [Re: Fancy87Raider] #703436 03/08/06 05:48 AM
Oyaji_Jon Offline
You guys all have very nice setups. I'm toying with how to set mine up now, and Frank, I'm thinking along the way you have yours with a small variation.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Power Inverters: Who's all got them? [Re: Oyaji_Jon] #703437 03/08/06 06:10 AM
JAVYPRO Offline
Today at SAMS Club I saw a 500 watts VECTOR unit for $29 <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.022s Queries: 16 (0.017s) Memory: 0.6448 MB (Peak: 0.7688 MB) Data Comp: Off Server Time: 2026-11-19 23:54:36 UTC
