Suspension Lift Question #703811 03/07/06 06:03 PM
jmcentire Offline OP
I'm not sure if anyone has done this, and I would assume this might make the ride horrible, but I wanted to get someone else's opinion. My 96 Rodeo currently stock, the rear sits about 1" lower than the front. I thought to even it out and still get the full 3" of lift I could use DOR's 3 replacement springs and Matt's Add-a-leaf(and a 1.5" shackel). Any opinions on this, would it make the ride quality horrible? Would it even work?
Thanks
95.5 Rodeo 4x4 V6
3" DOR Lift
33x12.5x15 BFG A/Ts
Re: Suspension Lift Question [Re: jmcentire] #703812 03/07/06 07:30 PM
strawmyers Offline
Isuzu Moderator
IMHO, get one or the other... not both. Have you ever driven a 1-ton truck unloaded? That will probably be about the same ride quality you can expect out of adding that many extra leaves to your pack. Final ride-height can be fine-tuned to some extent with shackle length. I have and would highly recommend the DOR Springs Upgradez. Great ride quality and still plenty flexy off-road. Never used the standard single, thick add-a-leaf, so no 1st hand experience to comment on there.
Sean Strawmyer
Re: Suspension Lift Question [Re: strawmyers] #703813 03/07/06 08:36 PM
Thanks for the info, that is what i expected.
95.5 Rodeo 4x4 V6
3" DOR Lift
33x12.5x15 BFG A/Ts
Re: Suspension Lift Question [Re: jmcentire] #703814 03/08/06 08:11 AM
maxwell417 Offline
Never used the standard single, thick add-a-leaf. I tried it, my comment, the ride was stiff, with no flex. Fine for a pickup hauling loads, bad for offroading. I am very happy with Darlington Springz upgrade <img src="/forums/images/graemlins/smile.gif" alt="" />.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6036 MB (Peak: 0.6595 MB) Data Comp: Off Server Time: 2026-05-30 01:18:56 UTC
