Can a c223 n/a head replace a c223t head #704005 03/08/06 02:12 AM
Tdamigo Offline OP
From the research that I have done so far shows that the only difference is the exhaust valve is smaller on the C223T head than the C223N/A.Does anyone know why and what would happen if I run this head on my C223T?
92 amigo w/C223T
Re: Can a c223 n/a head replace a c223t head [Re: Tdamigo] #704006 03/08/06 04:53 AM
JLEMOND Offline
OTHER THAN VLV SIZES ,AND THE HOT PLUGS IN THE COMBUSTION CHAMBER, YOU WON,T NOTICE ANY DIFF, AND IT WILL RUN JUST FINE, THE VLVS IN THE TURBO ARE OF A DIFF MATERIAL SO ARE THE HOT PLUGS , TO WITHSATND THE HIGHER THAN NORMAL EXHAUST TEMPS , SO DON,T GO FLOGGING THE DAYLITES OUT OF IT AND YOU WILL BE FINE , THE TURBO HEADS ARE GETTING HARD TO FIND , JERRY
Re: Can a c223 n/a head replace a c223t head [Re: JLEMOND] #704007 03/09/06 12:44 AM
Tdamigo Offline OP
Thanks Jerry,
I appreciate the info
92 amigo w/C223T
Re: Can a c223 n/a head replace a c223t head [Re: Tdamigo] #704008 03/09/06 04:37 PM
svanmatr Offline
Amazingly, a couple of years ago I was able to purchase a NEW c223t head with valves, installed from the dealer for around 1600$. This is after the previous owner blew 800$ replacing the head gasket only to find that the expansion chamber inserts had micro fractures in them, which the mechanic missed, and the gasket mating surface was no good and the vehicle continued to overheat. So have that used head checked real close.
Re: Can a c223 n/a head replace a c223t head [Re: svanmatr] #704009 03/09/06 11:08 PM
JLEMOND Offline
YEP THAT WAS A HIGH PRICE BUT A GOOD ONE A NEW CYL HEAD NOW IS 1207.00 WITH OUT THE VLVS AND OR SPRINGS OR ROCKERS QUITE A DIFFERENCE WITH NEW VLVS RUNNING 18-20 DOLLARS EACH AND NEW SPRINGS IT GETS QUITE EXP TO REBUILD THE TURBO ENG NOWADAYS JERRY
Re: Can a c223 n/a head replace a c223t head [Re: JLEMOND] #704010 03/11/06 01:39 AM
Tdamigo Offline OP
Thanks for the help guys,Is there a required way to break in a freshly rebuilt motor?
92 amigo w/C223T
Re: Can a c223 n/a head replace a c223t head [Re: Tdamigo] #704011 03/11/06 03:23 AM
JLEMOND Offline
YEP , IF IT WAS DONE CORRECTLY , GET IN IT AND GO ,KEEP THE RPM DOWN TO ABOUT 3-3500 EVEN AFTER A SHORT BREAKIN,THE MAIN THING WITH A DSL FOR THE FIRST 1000 MILES OR SO DO NOT PUT A HEAVY LOAD ON THE ENG , A LITTLE HIGHER RPM INITIALLY WILL HELP KEEP EVERYTHING OILED UP REAL GOOD INTERNALLY, BASICALLY DON,T LUG THE ENG JERRY
Re: Can a c223 n/a head replace a c223t head [Re: JLEMOND] #704012 03/12/06 02:15 AM
Tdamigo Offline OP
Thanks again Jerry,appreciate your help.
92 amigo w/C223T
Re: Can a c223 n/a head replace a c223t head [Re: Tdamigo] #704013 03/12/06 04:47 PM
turboDIESELtrooper Offline
Tdamigo, do you have any pictures of your Amigo or the work/rebuild of the diesel engine? A diesel Amigo has got to be cool. Thanks.
Salvy
Re: Can a c223 n/a head replace a c223t head [Re: turboDIESELtrooper] #704014 03/13/06 03:49 AM
Tdamigo Offline OP
No pics at the moment might take some after the swap,which hopefully will be in a couple of weeks.
92 amigo w/C223T
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6280 MB (Peak: 0.7187 MB) Data Comp: Off Server Time: 2026-07-15 12:46:45 UTC
