Page 1 of 4 1 2 3 4
synthetic oil #704116 03/08/06 08:29 AM
1
1991TrooperV6 Offline OP
https://www.amsoil.com
does anyone use this companies motor oil? They have an unusual marketing method. They recomend one oil change per year, or 25,000 change interval.
what oil type do you use?
single choice
synthetic (76%, 16 Votes)
vote for petrol (24%, 5 Votes)
Total Votes: 21
Voting on this poll ends: 03/20/06 07:23 AM
1991 Trooper LS / (rebuilt) 2.8 GM
free flow exhaust
Re: synthetic oil [Re: 1991TrooperV6] #704117 03/08/06 09:44 AM
Rodeofox Offline
Amsoil is a great oil for diesel's and should be for gassers as well. A friend of mine has is just over 20k on his last oil change.
Now the best way to know how your engine/oil is doing is to get a sample every 3-5k and send it to Blackstone Labs. Blackstone
They can tell you how it looks and what it contains. It's pretty cheap as well.
2001 F250 Larait 6spd
1994 Ford Lightning
1997 Rodeo
Re: synthetic oil [Re: Rodeofox] #704118 03/08/06 02:12 PM
ducktrooper Offline
I checked out their site.This sounds like a worthwhile test, especially if you're considering keeping a high mileage Zu for a lot longer and putting money into modifications. I wonder how the test results would be affected for those of us adding a qt. of oil every 1,000 miles or so.
Has anyone else heard of this lab and how accurate an indicator they are of potential problems?
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Re: synthetic oil [Re: ducktrooper] #704119 03/08/06 04:23 PM
Gizzy42 Offline
I didnt vote because I havent used their motor oil, but I have their manual trans oil in my rodeo right now. This is the first time I've used their product. I figured it was synthetic, blended for use in trannys, and the propper weight so might as well give it a try. I dont like using motor oil in areas where there are alot of gears. Even though it may be perfectly fine I feel that oil designed for that purpose is a better choice. I just wish you could buy it in stores instead of having to order it.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: synthetic oil [Re: 1991TrooperV6] #704120 03/08/06 05:34 PM
BigSwede Offline
I voted for synthetic because the poll didn't specify brand, but I don't use Amsoil, I use Mobil One. Been using it for nigh unto 20 years now with excellent results. FWIW I run it 10K with a filter change at 5K.
Serenity now!
Re: synthetic oil [Re: BigSwede] #704121 03/08/06 05:40 PM
W
Wayne Offline
Interesting way to do it. I didn't vote because I can't.
1. 93 Amigo: Cheapest dino oil I can get from Wal-Mart.
2. 2004 Rodeo: Mobile 1, 5k changes with Puralator pureOne filter.
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: synthetic oil [Re: Wayne] #704122 03/08/06 06:04 PM
ducktrooper Offline
Just curious, how much are people paying for Amsoil?
Re: synthetic oil [Re: ducktrooper] #704123 03/08/06 06:20 PM
Rodeofox Offline
Something you can do is goto this site. The Diesel Stop
Search for both Amsoil and Blackstone Labs. You will find a ton of reading material about both subjects.
Re: synthetic oil [Re: 1991TrooperV6] #704124 03/08/06 07:15 PM
Triathlete Offline
I have Mobil1 synthetics in the engine and diffs. Soon will be putting it in the trany/transfer case. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Billy
VEHICROSS.INFO
'99 Vehicross 3"OME lift Torsion bar crank Ball joint flip 31" BFG AT's (everyday)/MTR's (wheel'n) Trooper skids OBA...more to come!
Re: synthetic oil [Re: Triathlete] #704125 03/08/06 07:53 PM
CPOM Offline
I'm all about the cheapest oil, purolator pureone filters, and 3-5k oil change. I stripped down my 3.1 engine and inspected all bearings and everything on that engine looked geat and I ran the snot out of it from 87K to 175K. I was not easy on that engine.
CHRIS
98 Amigo, 92 Pup
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 21 (0.005s) Memory: 0.6509 MB (Peak: 0.8396 MB) Data Comp: Off Server Time: 2026-06-21 12:11:59 UTC
