I have a 92 Toyota Pickup #704609 03/09/06 08:27 AM
I have a 92 toyota pickup 2wd. Let me start with that I know this is a 4wd fourm but I figured that you might be the best place to ask this question.
Back to what I started to say... I have a 92 Toyota Pickup 2wd, DX, Extended Cab, 6' Bed, 2.4L 4CYL engine W/ 5 speed manual transmission. I recently threw a rod and am now need a new engine. The Question is what engines can I put in there.
I already know I can put in any of the 22RE between 89-95 From both a pickup and a 4-Runner. Now I have heard of people using the 84 Buick 3.8L V6 as a replacement for the Toyota 4cyl engine in a 89-95 pickup because the 84 buick 3.8 will bolt to the 5 speed manual for the 4cyl engine. What I am wondering is with out too much modification can I put the 2.7L I4 that toyota put in there Tacoma's 95-2001(I think they stoped in 2001) or the 3.4L V6 From the T100, Tacoma, Tundra. A Little help please.
My preference would be to stick with a toyota engine, and I do not want anything smaller then I already had. So preferably Somthing Larger than a 2.4L with more HP than 116 and more torq than 140 ft/lbs (i think that's what mine was rated at). any help would be nice
Re: I have a 92 Toyota Pickup #704610 03/09/06 08:54 AM
vrooooom Offline
2.7L 's exhuast and intake are on opposite sides. It can be done though.
you can also put in a 5mge or a 7mge inline 6 (supras or cressidas) they bolt up to the w56 tranny.
stock 1994 Toyota 4x4 XtraCab v6 SR5 pickup
Re: I have a 92 Toyota Pickup #704611 03/09/06 08:55 AM
kewlynx Offline
Have fun with this post:
Big Mike's Big Project The 2.7L has the same ponies as the 3.0L at 150hp.
Yer gonna work for it; ain't a drop-in.
www.car-parts.com
**ubi apis- ibi salus**
Re: I have a 92 Toyota Pickup [Re: kewlynx] #704612 03/09/06 09:01 AM
OK, I am aware that the 2.7L has the same number of HP as the 3.0L avalable for the truck. It seems very hard to find the 2.4L I4 and 3.0L V6 for my truck. What about the 3.4L what am I likely to run into on putting it in?
Also whats the chalange going to be on bolting up the I6?
Re: I have a 92 Toyota Pickup #704613 03/09/06 09:05 AM
kewlynx Offline
Never heard of anyone putting the 3.4 into a 2wd truck. As mentioned, the Supra swap is another option.
You Google yet?
Re: I have a 92 Toyota Pickup [Re: kewlynx] #704614 03/09/06 09:13 AM
A lot of the T100 and Tundra's with the 3.4L are 2wd.
Anyway here is the link to the place where I heard of a guy using a buick 3.8L
http://www.off-road.com/toyota/buick_v6_swap.html
I also heard of a guy using a Ford Mustang V8 but I don't remember where but he went through alot to get it working right.
Re: I have a 92 Toyota Pickup #704615 03/09/06 09:27 AM
kewlynx Offline
Interesting; don't see a lot of the 2wd versions up here; they don't sell very well. Either way, you'll be needing all the wiring, the ECU's etc, so it's a matter of namin' your poison and going for it.
A few 3.4 links; toggle them to reference via your 'my home':
http://www.4x4wire.com/forums/showf...79904&fpart=1&PHPSESSID=
http://www.4x4wire.com/forums/showf...34324&fpart=1&PHPSESSID=
http://www.4x4wire.com/forums/showf...16684&fpart=1&PHPSESSID=
Have fun reading!
We've got an FSM sticky'd for the 3.4 application over in the Taco section. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: I have a 92 Toyota Pickup #704616 03/09/06 05:04 PM
A
Andy87 Offline
Probably not what you want to do, but you can put in a turbo diesel (2L-T would be easiest) from an overseas Toyota.
Check out www.toyotadiesel.com, and www.jarcoinc.com.
It's not cheap, but it'll be a complete bolt-in, and you'll have no ECU to deal with.
'87 Xtra Cab, 4wd, 22r, 5spd
'92 Xtra Cab, 4wd, 2L-TE diesel swap, 5spd
http://toyotadiesel.com/forums/showthread.php?t=2502
Re: I have a 92 Toyota Pickup [Re: Andy87] #704617 03/09/06 06:10 PM
kyle-22r Offline
the 22RE shouldn't be too hard to find unless you live in the middle of nowhere. any 22R or 22R-E from 1985-1995 will work, you can just bolt your manifolds and sensors to it and call it good.
may have to swap oil pans though, if it came from a 4x4 truck or 4runner.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: I have a 92 Toyota Pickup #704618 07/11/06 09:15 PM
I have been meaning to tell you guyes that I did end up putting a 22r engine back in my truck it works fine and seems to be fairly powerful. Not as much work as some of the projects i have seen other go through for there trucks.
Also has anyone here Re-Painted there trucks and if so, any picktures and how much (ball park) did they spend.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6304 MB (Peak: 0.7537 MB) Data Comp: Off Server Time: 2026-06-25 01:20:26 UTC
