No.4 Plug full of oil #704953 03/10/06 12:01 PM
Lennyburger Offline OP
The last time [last time ever] I washed down the engine, number four [the one at the back of the engine] spark plug was covered in oil, below the coil pack but outside the engine. I figured then that it's the valve cover gasket. Is this a common dillema? I gues I'll have to replace the gasket soon as it makes for fun times when trying to get the socket over the end of the plug with all that oil filling the valley on that cylinder. It took me quite some time just to extract that plug becuse of all the oil so next time I do it I'll replace the plugs too. They all looked fine but I'd really like to try the Bosch +4 <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />ones everyone seems to have. Are they really that much better?
KIA, More dirt for ya dollar! 99 Sportage, Pod filter, Bosch Super4 plugs, electric thermo fan, racing pedals, Narva 100W driving lights, Yokhama 235/75R15 Super Diggers....getting to the rest bit by bit.
Re: No.4 Plug full of oil [Re: Lennyburger] #704954 03/10/06 12:37 PM
Axe Man Offline
Kia Moderator Emeritus
See steps 9, 10, and 11 in this thread...
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
If you let it go you may get misfire, which will destroy the cat convertor.
IMHO Bosch +4's don't provide any gains other than "feel good". I run OEM resistor plugs. They work fine.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: No.4 Plug full of oil [Re: Lennyburger] #704955 03/10/06 03:12 PM
tlab Offline
I actually put them in mine once and I had problems with them. I put the regular plugs back in and have used them ever since.
2001 dodge dakota bone stock right now.
check out the last love of my life on .....
http://members.cardomain.com/tlab1
Re: No.4 Plug full of oil [Re: Axe Man] #704956 03/10/06 03:43 PM
A
Airdale73013 Offline
Stock plugs are good for about 30k miles, the +4 I know from personel experience will last longer than 60k miles. I do not believe there is any performance gains for the +4 plugs.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: No.4 Plug full of oil [Re: Airdale73013] #704957 03/10/06 06:29 PM
Nukeiridium Offline
My valve cover gasket leaks oil all over spark plug 4 too. Recently I replaced the gasket and gooped tons of gasket sealer all over. Hopefull it won't leak this time. It is a common problem with these engines.
As for plugs, I have never had good luck with ANY high-end plugs in my sportage. I have tried bosch platinum, +4, and others and had problems like Axey.
Now days I usually use Denso plugs that have the copper contacts (I think?) and I replace them more often. Runs smooth as a baby's butt... Hey I figure use ***** plugs in a ***** engine smile
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: No.4 Plug full of oil [Re: Nukeiridium] #704958 03/11/06 07:14 PM
I've used Autolite and NGK V-power. Both seemed to work fine...changed @ 30,000 miles, of course.....I believe the V-power were OEM for the 2002......
Re: No.4 Plug full of oil [Re: Nukeiridium] #704959 03/13/06 04:20 PM
tlab Offline
As a matter of fact I just had to change my plugs, wires and coil packs last week or the week before. I noticed that the #4 area was free of oil for the first time ever. The lst time I changed the plugs I bought a new valve cover gasket and I made sure to follow the directions and tighten the bolts in the pattern specafied and I even went as far as to tighten them with my torque wrench to the specified ft/lbs. I guess it worked. I didn't use any gasket sealer at all.
Re: No.4 Plug full of oil [Re: tlab] #704960 03/14/06 01:11 PM
So what is the correct pattern and torque.
I am putting on a new gasket this week and want to get it right!
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
Graham
Re: No.4 Plug full of oil #704961 03/14/06 01:31 PM
Axe Man Offline
Graham
See step 11 here...
Re: No.4 Plug full of oil [Re: Axe Man] #704962 03/14/06 08:55 PM
Thx, hopefully no more oil in plug 4 in a few days.
Graham
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6323 MB (Peak: 0.7407 MB) Data Comp: Off Server Time: 2026-06-07 05:59:16 UTC
