4D56T turbo wiggle (good / bad) and Boost gauge #705411 03/12/06 12:32 AM
bill_bly_ca Offline OP
So swapped out the two front parking lights and rebuilt the headlamp washer the other night (boy does that thing spray, no wonder the impeller would ususaly shatter, good thing mine was just a rusty armature) and since I had the 10mm driver in hand I decided to take off the hose from the air box to the turbo to check it...
Turbine spins freely and the slop I would describe like (sorry if it is a poor analogy) what a M4 bolt would move side to side & up down if it had 6 to 10 threads engauged.. Good? Bad?? <img src="/forums/images/graemlins/confused.gif" alt="" />
Also I am thinking of moving the altimiter and putting a boost gauge in its place. I have to drill and tap the elbow from the turbo to the manifold. Is it better to put this fitting on the side?, Top?, Bottom? Any suggestions? <img src="/forums/images/graemlins/confused.gif" alt="" />
Thanx
97 Prado (LC 90 series) JDM import 2020 --- 2000 Galloper II SWB under offer from Korea
88 Mits Pajero LWB 185000Km 2.5TD JDM import (SOLD)
Re: 4D56T turbo wiggle (good / bad) and Boost gauge [Re: bill_bly_ca] #705412 03/12/06 03:09 AM
OKRED Offline
M-4 as in weapon or fastener? Either way it should have minimal play.
Here is what I did with my gauges, stock gauges are crap.
That is boost and oil psi.
A brand spankin new 1973 series 3 Landy
OLIVE DRAB SWB, TURBO, IN ABOUT 36 PIECES
89 TROOPER, RESCUED FROM THE YARDS. (Down again)
05 TACOMA CREW SHORTY.
Re: 4D56T turbo wiggle (good / bad) and Boost gauge [Re: OKRED] #705413 03/12/06 04:35 AM
52degrees Offline
What's that little vent between your guages? What does that do? Mine's covered by the guage pod.
Clay
KG6VNX
Re: 4D56T turbo wiggle (good / bad) and Boost gauge [Re: OKRED] #705414 03/12/06 05:37 AM
POLAK50 Offline
lol m4 you must have ties to the army or marines because i think thats still there assult rifle they use
88' Montero SWB 2.6L 5 speed, Got for free from my folks I couldnt stand the car I first drove just sit there and die.
Re: 4D56T turbo wiggle (good / bad) and Boost gauge [Re: POLAK50] #705415 03/12/06 06:21 AM
Raider_X Offline
shaft play is never good in a turbo charger.
RIP raider
Re: 4D56T turbo wiggle (good / bad) and Boost gauge [Re: Raider_X] #705416 03/12/06 08:34 AM
Kevin C Offline
If you allow .002 clearance per bearing surface and there are two surfaces per bearing, that says you can move each bearing .004". Since the bearings are well inboard of the shaft you will see double the movment at the end of the shaft.
Two bearings.. get even more movment.
Bottom line? .022" of movement at the end of the shaft is pretty normal. As long as the wheels have not rubbed the housing your probably OK.
Kevin
Re: 4D56T turbo wiggle (good / bad) and Boost gauge [Re: Kevin C] #705417 03/12/06 02:22 PM
OK... It is not even close to 22 thou.. Maybe 3 to 5 if I had to guess.
Re: 4D56T turbo wiggle (good / bad) and Boost gauge [Re: bill_bly_ca] #705418 03/12/06 03:04 PM
Kevin's .022" sounds right to me. I've successfully used up to 1mm, and .022"=.55mm
Do you have a waste gate? If so, for the boost gauge, tap the waste gate line from the turbo outlet with a tee for the gauge, or for that matter, any manifold tap upstream of the throttle - woops, diesel and no throttle - any tap, including the brake booster line before the check valve. I would avoid any metal drilling unless you are SURE you can get ALL the chips out.
Re: 4D56T turbo wiggle (good / bad) and Boost gauge [Re: 52degrees] #705419 03/12/06 08:22 PM
OKRED Offline
Clay
It's actually just a little access cover for a dashbolt. Plug is behind there for stock guage pod.
Re: 4D56T turbo wiggle (good / bad) and Boost gauge [Re: fasteddy] #705420 03/13/06 03:59 AM
So here then??
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6387 MB (Peak: 0.7623 MB) Data Comp: Off Server Time: 2026-06-07 09:06:26 UTC
