Valves tighten with age? #705841 03/13/06 07:38 AM
stock87 Offline OP
Just adjusted the valves on a friend's 89 2WD carbie that has pretty clearly seen little to no maintenance over it's lifespan (278k), and all the valves but one were WAY too tight. Is this normal? #2 exhaust was just tight enough so that the cyl had low compression and wouldn't fire at idle.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Valves tighten with age? [Re: stock87] #705842 03/13/06 07:56 AM
Manson Offline
Yes this is normal and is why they are supposed to be adjusted periodically.
Re: Valves tighten with age? [Re: Manson] #705843 03/13/06 05:44 PM
kyle-22r Offline
common sense would say that they'd loosen as the adjusters wear, at least to me <img src="/forums/images/graemlins/confused.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Valves tighten with age? [Re: kyle-22r] #705844 03/13/06 08:47 PM
MrWiretender Offline
The wear is on the valve seat as the valve sinks deeper into the head thus closing the lash gap.
'87 22RE
Re: Valves tighten with age? [Re: MrWiretender] #705845 03/13/06 11:42 PM
87Toy4x4 Offline
after my street rv head got broken in about 2k later i adjusted the valves for the third time. a lot of them were wayyy too tight, and some were really loose i was a little confused about that. now it sounds like they are loose again, ugh. ive been putting off adjusting my valves for a couple weeks.
Re: Valves tighten with age? [Re: 87Toy4x4] #705846 03/14/06 12:49 AM
ToYPU Offline
good so ill leave mine loose and theyll be in spec in about 50k miles <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
kevin <img src="/forums/images/graemlins/wink.gif" alt="" />
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6109 MB (Peak: 0.6801 MB) Data Comp: Off Server Time: 2026-06-09 21:58:43 UTC
