When to worry about low compression #'s. #706038 03/13/06 11:58 PM
Jickle Offline OP
I have a 92 xtra cab, auto, 4x4, with the 3.slow. 203,000 miles and I was checking compression numbers the other day on all the cylinders. I get:
#1 - 140
#2 - 142
#3 - 140
#4 - 145
#5 - 138
#6 - 142
Toyota specs, I think, says minimum psi is 142. Power in the engine is okay, nothing impressive. What is the lowest compression numbers I can tolerate? Will fuel economy, and power and performance all go down the drain soon? (The engine has been run out of oil once, and not by me)
Re: When to worry about low compression #'s. [Re: Jickle] #706039 03/14/06 12:07 AM
engnbldr Offline
#1 - 140
#2 - 142
#3 - 140
#4 - 145
#5 - 138
#6 - 142
>>>*Those readings are pretty typical of what we see reported with the mileage you have. I wouldn't be very concerned, you might consider readjusting the valves as when we see #5 or #6 begin to drop, a burnt valve is the usual reason....*EB
*Beats the he** outa me!....*LOL**...
Re: When to worry about low compression #'s. [Re: engnbldr] #706040 03/15/06 08:20 AM
I don't think those numbers are anything to worry about <img src="/forums/images/graemlins/kewl.gif" alt="" /> i do compression tests on vehicles all the time in automotive class and thats about right. though i would keep an eye on #5
Re: When to worry about low compression #'s. [Re: Jickle] #706041 03/15/06 03:44 PM
Jickle Offline OP
Great, thanks for the input fellas. I'll just run her like a toyota and keep checking the #'s. I just got a new pitman arm and idler arm and that truck really rides smooth, and straight. I used to have some pretty bad shuddering at higher speeds. Toyota kicks a$$
stock 92 pickup, v6, xtra cab, 4x4 IFS, 204k miles
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5986 MB (Peak: 0.6574 MB) Data Comp: Off Server Time: 2026-11-16 08:32:56 UTC
