Re: Engine Diesels after Weber conversion [Re: TobyB] #706055 03/18/06 12:49 PM
JAVYPRO Offline
Nice setup, now I will recomend a good engine degrease job to match your new carb. <img src="/forums/images/graemlins/smile.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Engine Diesels after Weber conversion [Re: JAVYPRO] #706056 03/18/06 03:41 PM
shadowgear Offline
Hi. I was having the same problem that you're talking about and I couldnt figure out what was wrong with it so I took it to Mitsu and even they couldnt dial it in right. Since it was all aftermarket, they were reluctant to look at it. They told me that it was probably worn jets and left it at that. So needless to say, I was forced to use the clutch trick method everytime. However, since blowing my head gasket and fixing all that, I have found that by fiddling with the distributor (timing?) I have almost got it to stop completely. Still have it in humid or really cold weather, but its that often that it happens. It doesnt smell like its running rich and it idles at around 600-750 when cold. Once its warmed up, it idles fine at around 750-800 rpm. I have also blocked the EGR and have had no issues with idle or fuel consumption. Hope this helps.
'88 Raider 2.6L - SW Hubs, Weber 32/36, Off-road Pkg - Dead
'88 Monty 2.7L - 5" Lift, Weber 38, 33's, Dual Fans, Dual bouncy (more goodies to install) - Still Kicking.
'03 Monty Sport - XLS, BFG A/T's - Dead
Re: Engine Diesels after Weber conversion [Re: shadowgear] #706057 04/19/06 08:06 PM
oewii Offline OP
I adjusted the fuel mixture after living with HORRIBLE gas mileage and the dieseling problem. Both those problems seem to be corrected.
1988 montero
31X10.50X15 Pro Comp A/Ts on 15X8 Rock Crawler 97s
Weber conversion with carter fuel pump. Roof rack in progress.
*Update* Re: Engine Diesels after Weber conversion [Re: oewii] #706058 07/28/06 06:35 AM
oewii Offline OP
Just to update on the Weber problems. I adjusted the fuel mixture and idle. I also added a throttle return spring which helped the sticky throttle. This also allowed me to dial in the idle. It still diesels once in a while but is MUCH better. I can get 17MPG on the Highway if I don't have a stiff headwind. That isn't factoring the tire size. Also, still working on the roof rack which is noisy and probably hurting the gas mileage a little.
1988 montero
Re: *Update* Re: Engine Diesels after Weber conversion [Re: oewii] #706059 07/30/06 03:36 AM
what kit did you use for the conversion and what does it cost for it? just curious a link would be Great!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6113 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-06-17 10:48:02 UTC
