Fog Lights
#706073
03/14/06 12:36 AM
Okay I am wiring up some ProComp 8 inch foggies. I am using a factory switch. I need to make a harness for it but there are 5 prongs on the back anyone kknow what they are 4? Why 5? 1998 isuzu rodeo. factory switch
Re: Fog Lights
[Re: MountaineerIsuzu1]
#706074
03/14/06 01:24 AM
I have never pulled one of those switches off but it almost makes sense that that would be a built in relay. I am probably way off on that but someone else should chime in anytime now.
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: Fog Lights
#706075
03/14/06 05:48 AM
Before you tear into that switch it would probably be much easier to use the stock fog light wiring and relay as chances are that your Rodeo is already wired for fog lights. All it needs is the relay, switch (which you already have) and some lights. Not sure about 2nd Gen, but the wires should be taped up between the headlights and fender, You should be able to either buy the Isuzu foglight pigtails and splice your aftermarket fog lights into them or cut off the connector and hook up there.
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: Fog Lights
[Re: Canucklehead]
#706076
03/15/06 02:32 AM
I already have factory fogs. I am mounting these on the rack with a factory switch in the change bezel in the center console. I just need to know the wiring specs on the 5 prongs on the back of the stock switch. That way I can construct a female harness. But thanks for the try. Anyone have wiring specs on these? 2nd gen. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Fog Lights
#706077
03/15/06 04:37 AM
Just ohm out the switch. Put a meter on it and go from pin to pin. Start with a lead on one pin and put the other lead on another pin... With the switch pushed in, see if you get continuity. If so, turn the switch off and see if you have continuity. If it breaks the circuit, you found your two wires to work the relay. If it doesn't, proceed to the next wire until you find the two.
One of the wires will also be a ground for the LED or bulb in the switch, if it's an illuminated switch.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake 1989 Trooper 2.6 auto 1989 I-Mark RS DOHC 1.6 1991 Stylus XS DOHC 1.8
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6042 MB (Peak: 0.6687 MB) Data Comp: Off Server Time: 2026-07-13 15:48:28 UTCValid HTML 5 and Valid CSS
