Sequoia DRL's Disconnect? #64344 01/01/03 09:35 PM
Rob_dup2 Offline OP
Has anyone with a Sequoia '02 found a way to Disconnect the DRL's? I have not fully looked into this (fuses/relay's,heat sink looking item as on the 01 4runner's) but thought I would see if anyone on the board has accomplished this yet?
Thanks
Re: Sequoia DRL's Disconnect? #64345 01/01/03 10:21 PM
If I remember correctly, look in between your fender (driver's side) and the battery. There should be a gray connector near the headlights (not the one connected to the headlights) but still on the fender side. Unplug that connector, tape the ends so you don't encounter a short circuit, voila...no more DRL.
[EDIT]Okay I got off my lazy butt and checked it out. It's the two wire connector (you'll see two wires coming out of it) on the fender side, on my Tundra, it's really near the headlights but still sandwhiched in between the battery and the driver's side fender (probably want to remove the battery to get to it).
<small>[ January 01, 2003, 04:33 PM: Message edited by: Mohamed ]</small>
PHP: 7.4.33 Page Time: 0.014s Queries: 14 (0.011s) Memory: 0.5858 MB (Peak: 0.6350 MB) Data Comp: Off Server Time: 2026-11-18 22:35:46 UTC
