Page 2 of 3 1 2 3
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: saswok] #706808 03/16/06 10:51 AM
mosk Offline
Your non-turbo motor requires non-turbo injectors and a non-turbo ECU and AFM. If he reused these parts from the turbo motor, he made a big mistake.
My advice would be to get the right 22RE injectors (for a pre 88.5 22RE), and a pre-88.5 ECU and AFM. You need the pre-88.5 parts to match the stock wiring harness; in 1989, Toyota changed to saturated injectors, and those have ovalized connectors. The stock pre-88.5 injectors are peak and hold and have square connectors. Install those and fresh plugs and everything should be in agreement.
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: mosk] #706809 03/16/06 05:32 PM
Reliability isn't a problem with the turbo motor. But like I said, they can get pricey real quick. You should be able to sell the turbo ECM, AFM, injectors, turbo, manifold pretty easily to offset the cost of finding the correct ECM, AFM and injectors.
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: mosk] #706810 03/16/06 07:19 PM
saswok Offline OP
thx so much guys!
mosk i was wondering when you were gonna show.
they tell me your the turbo guru and now i can move forward with getting the right parts. should i get new or used on the injectors and afm? i wont be buying the ecu new! any one have a spare good ecu they want to part with?????
i did read on here to buy toyota injectors period...
1987 reg cab turbo w/o the turbo and a 1994 22re in it, need help please.
1997 bmw 540i/6 blk on blk
lynnwood, washington
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: saswok] #706811 03/16/06 08:24 PM
RAZZMATAZ Offline
I do believe that the 22RTE injector and ECU will over fuel the 22RE engine!! You can tell the turbo injectors from the NA injectors by the color.. the turbo injectors are pinkish/orange and the NA injectors are grey.. The UCE is also easly to tell apart and is located in the passenger kick panel it will clearly state if itÆs a 22RTE or a 22RE ECU.. IÆm almost certain that the wiring harness are identical except for the boost sensor on the turbo harnessàbut the turbo harness should work fine on the NA motor.. As for the MAF sensor I have no idea how to tell them apart they might have a sticker donno!?!?!
time to go junk yardin!!
BE Wild,
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
Detroit in rear, Lockright in front
35 MT/R
Rancho 9000
Jacobs ProStreet ign module and Ultra coil
1992 3VZ-E swapped in
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: saswok] #706812 03/16/06 08:29 PM
4WD22R Offline
saswok: PM'd you.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: saswok] #706813 03/17/06 10:06 AM
saswok Offline OP
ok so i picked up the truck today and it ran rough but made it home fine lol!!!!
i am trying to locate the afm and injectors tomorrow.
wrecking yard time!!!
two nice gents on here are helping with the ecu, thx guys.
wow looks like alot of work to replace the injectors.
will i need a new intake gasket for the job?
any other advice on pulling the intake and replacing the injectors, any tricks? thx again
amazing bunch of guys on here!
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: saswok] #706814 03/17/06 06:42 PM
RAZZMATAZ Offline
it's not really that bad to change out the injestors, but you will need a new plenuim gasket.. I'd also replace both the upper and lower O-rings on each injector as well as the little screen on the injectors.. If you get them from a junk yard clean them real good with brake cleaner.. not carb cleaner as the carb cleaner will make the plastic parts brittle..
HTH,
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
35 MT/R
Rancho 9000
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: saswok] #706815 03/17/06 08:05 PM
MuddRunner Offline
Read this post Label everything... wires, hoses, tubing, sensors... take pictures if possible... never think that "I'll remember where everything went when I'm done".
Also, use caution when removing the metal clips on your injector and TPS connections (if you have them), I ruined mine on my first 22RE rebuild.
'92 Pickup x-cab, 22re, auto.
'50 Ford Tudor Sedan, my new "Hot Rod"
Too much to do, too little time/$$$
Heb. 12.3
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: MuddRunner] #706816 03/17/06 11:09 PM
mosk Offline
This is an excellent point -- these plastic/bakelite/whatever casings that the metal clips reside in become brittle with age and break easily, also the clips can bend. So use something like a small, fine bladed screwdriver a pry these off very gently. Be careful and take your time.
Also, a trick for reinstalling the injector o-rings is to use a little (little!) Vaseline as lube, this keeps the o-rings from getting twisted and damaged/torn.
-Jeff
Jeff Moskovitz
Jeff's 22R-TE page
Re: just bought a 1987 yota turbo? yota noobie here was a bmw guy? [Re: mosk] #706817 03/19/06 10:07 AM
saswok Offline OP
OK-
so now i have ecu,afm,injectors w/ new o rings,new upper fuel intake piece because the turbo one was missing a port that connects to the top of the valve cover, my new intake was very dirty inside w/black goop and carb cleaner didnt make a dent. how should i clean the goop outta there?
also the toyota guys helping me locally think i should buy a new wiring harness non turbo, because it has alot of different connectors that we wont need. they also thing my timing may be a tooth off on the distributor because they say the cap looks off a little. i pulled off the oil fill and alot of air blowing out, isnt this blowby or is it because of how its running, or is it just normal because the engine is supposed to have 90k on it...
so i pulled some wierd tubing and a cannister by radiator on the drivers side and sensors that the local guys here told me i dont need. then i put the new o rings on the injectors. i took the throttle body and linkage from the turbo manifold because it was way cleaner and so the throttle cable would match up(hope this is ok)the turbo throttlebody had two small vaccum tubes and the efi throttlebody has three...
as soon as i get the intake cleaned i will install it all
then maybe go for the wiring harness or just see if it works like this.. what do you pros think let me know!!!!
thx guys...
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6420 MB (Peak: 0.7666 MB) Data Comp: Off Server Time: 2026-06-17 10:38:18 UTC
